hp g62 bios dump
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    hp g62 bios dump
    my friend
    g62-b37st
    intel processor
    no display
    bios + kbc dump
    schematic help
    mainboard.010140u00-600-g
  • robrock1
    • Jul 2013
    • 129
    • Ghana
    Re: hp g62 bios dump
    Check this files.
    • rajeshkumar
      • Oct 2014
      • 44
      • india
      need bios dump g42 da00ax2mb6f0 rev-f
      • nacer
        • Feb 2016
        • 130
        • alger
        Good gooooooooooooooooooood
        • kokok
          • 9
          • indonesia
          need bios G42 360TX...ANYBODY HELP ME....
          • mwmakki
            • Sep 2017
            • 9
            • Aleppo
            thanks
            • toufik sat
              • Feb 2016
              • 134
              • los angles
              thanks
              • bilalahmad
                • Aug 2016
                • pakistan
                Need hp g60 bios
                • maybel
                  • Dec 2017
                  • 24
                  • philippines
                  DO YOU HAVE hp presario cq62 REV:C BIOS DUMP
                  • kaplans26
                    • Mar 2020
                    • Türkiye
                    hp g62-b16st bios help
                      • 20764
                      Post your bios backup .
                      • kaplans26
                        • Mar 2020
                        • Türkiye
                        I accidentally deleted the backup
                          • 20764
                          You want $BID01439 see post #5 https://www.badcaps.net/forum/showthread.php?t=45741 .Use the second with no DMI ,then you`ll need to use nbdmifit to enter the DMI info https://www.badcaps.net/forum/showthread.php?t=69204
                          • trtr
                            • Jan 2021
                            • Türkiye
                            Originally posted by asliyucegsm
                            my friend
                            g62-b37st
                            intel processor
                            no display
                            bios + kbc dump
                            schematic help
                            İntel uma run bios
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • DynaxSC
                              by DynaxSC
                              11-17-2023, 10:56 AM
                            • grimacelord
                              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                              by grimacelord
                              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                              Motherboard model number: DA0PAMB46A1 REV: A
                              Secondary motherboard model number: 0PAB
                              SKU: 685K4UA
                              Serial number is: 5CD3223BJP
                              Recently reflashed this laptop with latest BIOS and once...
                              05-07-2024, 08:06 AM
                            • DynaxSC
                              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                              by DynaxSC
                              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                              11-06-2022, 05:22 PM
                            • TacticalFahrrad
                              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                              by TacticalFahrrad
                              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                              06-30-2025, 04:09 AM
