SAMSUNG NP700Z7C - BIOS dump needed
  • bello
    • Oct 2011
    • 7
    • Bosnia and Herzegovina
    Re: SAMSUNG NP700Z7C - BIOS dump needed
    There is original, maybe corrupted:
    • techman1025
      • Jun 2014
      • 497
      Here
      Techman1025
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        try this.
        • bello
          • Oct 2011
          • 7
          Thanks for fast answer. Flashed with techman1025 dump now I have progres bar with Phoenix logo but stucked, can't enter into bios with F2 or F4. With whaldsz dump behaves same as original...
          I think motherboard is bad??
          There's pictures:
          • techman1025
            • Jun 2014
            • 497
            Hi
            Pull Cmos battery for a few min and hold power button down then plug adapter only and retry.
            Techman1025
            • bello
              • Oct 2011
              • 7
              #26
              I tried it already...
              Customer says that sometimes the start, after many attempts. The disc is correct, it is possible that the failure of the board ...
              • techman1025
                • Jun 2014
                • 497
                Hi
                You could try a new bios chip and reprogram it with mine. Also try with only one memory stick in and do the same for the other socket see if it hangs so only one at a time you might have a bad stick of memory or a bad socket if one socket is bad double up on one socket is the only fix.
                Techman1025
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  #28
                  ok, try again with this one.
                  • bello
                    • Oct 2011
                    • 7
                    #29
                    @techman1025
                    I tryed it also, one memory is soldered on the board and can't remove it. Also tryed with another bios chip...
                    @whaldsz
                    Nothing, same as other...
                    Anyway thanks a lot.
                    E.Lelic
                    • techman1025
                      • Jun 2014
                      • 497
                      Hi
                      What i would do is put some good flux under the onboard memory chip's and apply a little heat like 100C then retest if it works you could always replace them.
                      Techman1025
                      • bello
                        • Oct 2011
                        • 7
                        #31
                        I tried to provoke him in the hot state, but nothing...
                        I think I'll give up.
                        • techman1025
                          • Jun 2014
                          • 497
                          I AGREE
                          Techman1025
                          • lining
                            • Mar 2017
                            • Macedonia
                            #33
                            NP700Z7C ba92 11017b dump maybe? accidentally erased the stock firmare before backup it first in my programer. I tried with last firmware whaldsz posted for BA92-10916B and only get backlight of the display and then he is restarting again and again and again
                            • jadao
                              • Sep 2015
                              • 10
                              I need NP700Z7C BA92-10916A working bios, any chance someone have it?
                              It is stuck in samsung logo.
                              Here is the suspected not working dump.
                              • xe_d_sono
                                • Aug 2013
                                • 24
                                • Portugal
                                #35
                                The solution to this Samsung Series machine is remove the dead iSSD flash from Sandisk. This cause a long freeze on boot.
                                I hope it helps.
                                Br
                                • Deby
                                  • Aug 2015
                                  • 52
                                  • Serbia
                                  #36
                                  I hope it helps.
                                  Br
                                  Thank you!!! It's Works
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • DynaxSC
                                    by DynaxSC
                                    11-17-2023, 10:56 AM
                                  • TacticalFahrrad
                                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                    by TacticalFahrrad
                                    I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                    BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                    06-30-2025, 04:09 AM
                                  • Kjell
                                    Samsung Series 9 - BIOS issue
                                    by Kjell
                                    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                    08-01-2025, 09:15 AM
