hp elitebook 8460p bios
Re: hp elitebook 8460p bios
HELLO ALLS
CAN any one help for unlock my dump of hp 8460p
thanksAttached FilesComment
Try this.Attached FilesComment
I have same laptop hp elitebook 8460p. This laptop shows the below error:
System information not valid
System board(00A) -
Product Name -
Product serial Number
Product SKU -
System board CT number-
Can this file solve the problem ? And how to use this file?
Please help, I will be very great full.Comment
Use wndmifit from windows, or use nbdmifit from dos. Version 2.10 .If that version doesnt work try some others.If MPM is locked you need to get "Manufacture Programming Mode in Unlock mode MPM"I have same laptop hp elitebook 8460p. This laptop shows the below error:
System board(00A) -
Product Name -
Product SKU -
https://www.badcaps.net/forum/showthread.php?t=69204Last edited by SMDFlea; 02-03-2019, 09:21 AM.Comment
Post here bios file..I have same laptop hp elitebook 8460p. This laptop shows the below error:
System board(00A) -
Product Name -
Product SKU -
hi friends, I have a problem with an elitebook 820. Show this post system board (00a). I would like to figure out how to get the number to put inside because whatever I enter I get a crc error TKSComment
			by AhariHi all,
I...-
			by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
			Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
S/N : 5RNK9FFT70...-
 - Loading...
thank you, man.
