hp elitebook 8460p bios
Re: hp elitebook 8460p bios
HELLO ALLS
CAN any one help for unlock my dump of hp 8460p
thanksAttached FilesPremium supporters get full download access and other benefits.
Try this.Attached FilesPremium supporters get full download access and other benefits.
I have same laptop hp elitebook 8460p. This laptop shows the below error:
System information not valid
System board(00A) -
Product Name -
Product serial Number
Product SKU -
System board CT number-
Can this file solve the problem ? And how to use this file?
Please help, I will be very great full.Comment
Use wndmifit from windows, or use nbdmifit from dos. Version 2.10 .If that version doesnt work try some others.If MPM is locked you need to get "Manufacture Programming Mode in Unlock mode MPM"I have same laptop hp elitebook 8460p. This laptop shows the below error:
System board(00A) -
Product Name -
Product SKU -
https://www.badcaps.net/forum/showthread.php?t=69204Last edited by SMDFlea; 02-03-2019, 09:21 AM.Comment
Post here bios file..I have same laptop hp elitebook 8460p. This laptop shows the below error:
System board(00A) -
Product Name -
Product SKU -
hi friends, I have a problem with an elitebook 820. Show this post system board (00a). I would like to figure out how to get the number to put inside because whatever I enter I get a crc error TKSComment
by wrinexHi i received a HP elitebook G6 that had a The HP Endpoint Security Controller error when booted but 3 enters later you could use it in windows, i thought maybe a bios update helps...... i used the HP tool (it did not want to update from device manager,,, someting i did not even knew worked) after the update it bricked the laptop.
i get 7 blinks on the capslock and thats it. i desoldered the chips front and back. and made a dump. i tried one bios posted here for the 16M and the 32Mb bios.. but it would not turn on or give an error code. so now i reflashed it back in its failed state...-
Channel: BIOS Requests ONLY!
by AhariHi all,
I...-
by JunhijamHi, I'm new to all of this so I hope I'm doing correctly and not breaking any rules.
I need help for my MSI PRO B660M-A DDR4 motherboard BIOS dump.
The motherboard got bricked during BIOS update due to a power cut in my village while updating BIOS. Now the PC is not booting. Fans kept spinning and no display is coming.
A local technician said I need the full BIOS dump/file for this motherboard.
My Motherboard model is:
MS-7D43 REV 1.0
The Bios chip is:
MXIC
MX25U25673GZ4140
Please, if anyone has the same board...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by kinojk2Hi, Thanks for all you do here.
I have attached my 16MB dump.
EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
EDIT:
I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
The clips are such a pain to use, soldering would be a great skill to have.
Thanks for the advice in other threads!
To answer my own question, I didn't...-
03-24-2026, 05:55 AM -
- Loading...
thank you, man.
