bios programer
  • laptopservice
    • Oct 2013
    • 35
    • india
    bios programer
    hai
    which one is best and cheap bios programer? please let me know
  • dj_ricoh
    • 2073
    Re: bios programer
    So let me understand .
    Its this Q like on Yahoo Answer?
    Let me get this you type on eBay BIOS programmer and you did not get any results?
    Mistery keyboard you got there sir.
    Nvm I use ezp BIOS programmer it has a auto function to detect the chip so my BIOS flashing its not a pain I.t.a
    • dycc
      Vision
      • Nov 2011
      • 624
      • CΓ΄te d'Ivoire
      Re: bios programer
      lol . also use ezp bios programmer
      http://www.ebay.com/itm/EZP2010-High...item19d224048b
      • robrock1
        • Jul 2013
        • 129
        • Ghana
        Re: bios programer
        I use willem eprom programmer, the older parallel type because i got it just $30 but there is an usb version out, its supporting many ic.
        • masud
          • Jul 2011
          • 317
          • Bangladesh
          Re: bios programer
          does it support most of the bios chips and works fine for all different sized chips?
          • masud
            • Jul 2011
            • 317
            • Bangladesh
            Re: bios programer
            i use superpro 600p. but its bit pain on chip identification.
            • dj_ricoh
              • 2073
              Re: bios programer
              yee
              i`ll take a screen shot monday
              if i had a better pc i would have recorded
              • tujuhkalitujuh
                • Oct 2013
                • 26
                • Indonesia
                Re: bios programer
                I use Willem programmer, although it uses Paralel Port but it's cheap and support many Sockets.
                Search: willem programmer
                • masud
                  • Jul 2011
                  • 317
                  • Bangladesh
                  Re: bios programer
                  yee
                  what are you talking about, i can't get you.
                  • dj_ricoh
                    • 2073
                    Re: bios programer
                    the software can see what type of chip its connected you only need to provide its the rom file
                    • tomodachi
                      • Apr 2012
                      • 593
                      • Turkey
                      Re: bios programer
                      what do you guys think about xeltek superpro m ? I want to buy one for flashing laptops and STB flashes.
                      • lord
                        • May 2011
                        • 319
                        • Croatia
                        Re: bios programer
                        I also have EZP. Detection is working OK.
                        I had problems today, actually, it couldn't detect ST24C02, but the IC is a WP (write protet) version so that could explain it, but still think it should detect it.
                        Also, can't fit bigger (non 8pin) ic's.
                        • spidey
                          climbs
                          • Dec 2012
                          • 648
                          • Cyprus
                          Re: bios programer
                          i'm using willem pcb7.5 and working fine, it is a little bit slow but i didnt have any problems on 8pin spi roms.
                          • STKR123
                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                            by STKR123
                            Greetings badcaps community,
                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                            I learned that desoldering...
                            10-29-2024, 06:03 AM
                          • hotcrossedbuns999
                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                            by hotcrossedbuns999
                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                            3. I could only locate two chips that look like bios chips. Could someone verify this
                            01-03-2025, 12:32 PM
                          • zlr8r
                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                            by zlr8r
                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                            cheers
                            Dell Inspiron 17 (7786) Laptop
                            Service Tag: 5J0NHT2
                            Bios: 1.9.0
                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                            Attached;
                            1. My saved bios using a programmer
                            2. Dells Bios updater .exe (v1.16)
                            3. Dells Bios recovery file
                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                            5. Image of ME...
                            12-18-2023, 03:08 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • what_1282105
                            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                            by what_1282105
                            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                            02-14-2025, 07:27 PM
