Need BIOS: Samsung RC520 (jinmao-r)
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Model number is jinmao-r
    Need BIOS file. Tried to reflash and program said failed. Tried new bios chip and same.
    Thanks.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: Need BIOS: Samsung RC520 (jinmao-r)
    Try to look for it with the board model instead. Same applies to schematics.
    i.e. - BA92-08082A, BA41-01581A, etc.
    Good luck.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    • speedypro
      • Feb 2013
      • 561
      • United Kingdom
      The file was ok..strange. But I forgot to make, on the MB, the location of pin 1
      Any pointers to locate pin 1 or the schematic? Searching with the model number brings up nothing.
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        Like i said before, you're looking with the wrong model nr.
        Try Harder!
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          This is the model: BA41-01580A. Nothing
          • Francisco.s
            • 686
            • Spain
            Thanks.
            Have you make a backup of the old bios?
            Please post it.
            • speedypro
              • Feb 2013
              • 561
              • United Kingdom
              Please post it.
              Yup.
              Here:
              https://www.badcaps.net/forum/attach...1&d=1381831309
              I need to do a reball anyway but would like to know where pin 1 is located.
              • Francisco.s
                • 686
                • Spain
                Yup.
                Here:
                I have download bios file from Samsung support, (BIOSUpdate.exe) and can`t extract any bin, rom, fd etc.
                How do you extract the dump file?
                • dj_ricoh
                  • 2073
                  did you try with 7-zip?
                  • Francisco.s
                    • 686
                    • Spain
                    Yes, I have tried 7zip, and let me see the files inside, but the largest one, is less than 1,3 Mbytes.
                    (I have attached a screen capture of 7zip)
                    • speedypro
                      • Feb 2013
                      • 561
                      • United Kingdom
                      Never did. I got it off the actual bios chip.
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1490
                        • portugal
                        well its easy to know wich is pin \1 put your multimeter on continuity , and chek all pins to ground , the ones that will BIP(make noise) is pin 4 GND ... therefore will be easy finding pin 1 :P
                        • dj_ricoh
                          • 2073
                          pin 1 its always mark with dot or line aside the chip.
                          usually they make a white square around the chip and near the first pin they make the line a little bigger!(white line)
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1490
                            • portugal
                            dj ricoh .. no samsung dont have any kind of marks , im with the same board , board model is 720 .. and its almost same board , and they dont give you position pins , unless for main QFN or KBC
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1490
                              • portugal
                              bios , fets etc , no position , but also who need positionn :P
                              • dj_ricoh
                                • 2073
                                every soic 8 pin chip got a whole or some paint on it!
                                very hard to see. put a tweezer soft on top and and search it
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1490
                                  • portugal
                                  dj ricoh hes mentioning about pin1 on the board and not the fet
                                  • dj_ricoh
                                    • 2073
                                    ohhh!
                                    now that`s dum not to remember the position
                                    and yes your right with ground only you can find it!
                                    Whole in chip pin1, 4 ground ; board ground then count back to pin one and you found it
                                    • tech_musiquero
                                      • Sep 2020
                                      • Philippines
                                      Thanks! It works 😊
                                      • tony stark
                                        • Aug 2017
                                        • 36
                                        • india
                                        yup.
                                        Here:
                                        i need to do a reball anyway but would like to know where pin 1 is located.
                                        this bios is ok... Thanks for share , jinmao-r
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
