We've all been in the situation; power but nothing on screen. Usually either going to be the graphics, or the BIOS. I read alot about people replacing the BIOS chip on here - how do people confirm it? I've scrapped a lot of laptops for this!
Diagnosing a bad BIOS?
Re: Diagnosing a bad BIOS?
There isn't an easy way to do a correct diagnostic. First, tray what is less difficult to you. (possible program the bios is easy) -
I would start with gpu. I go bios route if power issues. Coils included. But check gpu. BTW, what model laptop?Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
Power issues? In what sense?Comment
I've always been a bit confused by this, too. How likely is it that a BIOS chip just "go bad" at random?Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSDComment
Just try an error for the cheap solution first. Almost intel motherboard is come with bios chip problem the rest amd model common problem with gpu. If u really want procedure to check bios measure the pin from sio chip. Sio send memory read and write to bios then check power button switch without press power button there present 3v or not.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
