dell inspiron 1545 bios password
  • trebo
    • 514
    • Wales, UK
    Re: dell inspiron 1545 bios password
    Originally posted by Ballerbude
    Now i Tried "I" and a low L also l an always the same. pls tell me if i do correct i type in what the generator tells me and the i pressed ctrl and hold it down and push enter. Is this right? i tried also to change z to y and it dosent work for me....any ideas?
    best wishes
    yes that's right
    also try just enter on its own , and enter twice, I cant come up with any thing else
    • shehzad
      • Oct 2013
      • pakistan
      please someone can give me the administrator password for this code#5m11tm1-2a7b
      • trebo
        • 514
        • Wales, UK
        you can try this, 5purSN9E3w60Oc7v
        careful, it is case sensitive
        entered on a qwerty keyboard
        hold down control and then press enter
        good luck
        here is a link to generator, http://bios-pw.org/
        • lkandil
          • Feb 2014
          • maroc
          s'il vous plait quelqu'un ici peut il me calculer le mot de passe bios pour ce code:
          #8JCQVM1-2A7B
          • gvike07
            • Feb 2014
            I am not getting the key gen to work. Could someone explain or help. I need a password for #7JTHBH1-595B
            • Microbe
              • Feb 2014
              • 17
              • Yemen
              #26
              hey JUTATY is it HDD password???
              try this "d5sye31b" ............ type the password, Then holding CTRL push ENTER key twice.
              • trebo
                • 514
                • Wales, UK
                #27
                hello gvike07
                try this, abblwvr (lower case)
                press enter, or sometimes hold down control then press enter
                good luck
                as for using generator, all you had to do was paste or type your code into it "7JTHBH1-595B" (always upper case) then click on get password,
                • trebo
                  • 514
                  • Wales, UK
                  #28
                  should have been, 5HR3uihz9J95e26c
                  • halimc220
                    • Mar 2014
                    • Ireland
                    #29
                    please someone can give me the administrator password for this code #4G65VY-1F66
                    • ibraha
                      • Mar 2014
                      • qassim
                      #30
                      goooooooooooooooooooooood
                      • kouddane
                        • May 2014
                        • maroc
                        #31
                        please someone can give me the bios password for this code: C5SYTZ1-1F66
                        • bdd
                          • Jul 2014
                          • Malaysia
                          #32
                          P.S. And I've tried different combinations of 1,I,l...
                          Also, I've found that the actual serial number on the HDD is one character more, it starts with WX41...
                          But still no luck with unlocking it. Is there anything else I can do?
                          • trebo
                            • 514
                            • Wales, UK
                            #33
                            Originally posted by bdd
                            Hey guys,
                            I've tried the tool online as well as downloaded binary, but it doesn't work for me.
                            I even tried compiling it myself on lubuntu, but that actually gives me a different output for my HDD string.
                            Your tool gives me: sLIwFXElxR69mCQN online as well as in windows executable
                            My compiled dell.c gives me: plpyukbs
                            I've tried using external keyboard and enter with ctrl pressed, etc. My keyboards are QWERTY.
                            My details:
                            Dell Latitude E6420
                            BIOS A03
                            Service Tag: C49P5Q1
                            Express Service Code: 26379543097
                            HDD: #X41A41K3578-2A7B
                            Please someone advise me what I can do to save this hdd. Thank you!
                            I have entered it this way, WX41A41K357-2A7B
                            and got this, x1jlIGv7ZWiCED90
                            worth a try because some bios take 11 from left and some take 11 from right
                            good luck
                            Codes need to be entered on a Qwerty keyboard
                            they also are Case sensitive, so enter as seen
                            sometimes pressing enter is enough, but other times you need to hold down control and then press enter, and then again sometimes you need to hold down control then press enter twice, hope that helps
                            • honey
                              • Aug 2014
                              • Pakistan
                              #34
                              <<I mean master bios password>>
                              • vince954
                                • Oct 2014
                                • usa
                                #35
                                could someone help me with a bios password for FF8KDS1-1D3B
                                • pham038
                                  • Dec 2014
                                  • viet nam
                                  #36
                                  Re: dell latitude e6410 bios password
                                  No body help me? Please.
                                  • borbooroski
                                    • Mar 2014
                                    • 177
                                    • Ghana
                                    #37
                                    #5n0b8l1-2a7b, hellp me
                                    • trebo
                                      • 514
                                      • Wales, UK
                                      #38
                                      try this, vhM4gyMN1K2DGsRC
                                      • venkatrao
                                        • Dec 2014
                                        • 7
                                        • india
                                        #39
                                        help me sir dell 1545 working bios!!!!!!!
                                        • ala_borbe
                                          aka Donald
                                          • 1625
                                          • Malta
                                          #40
                                          backup your bios and try this
                                          Im Back... sort of...
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • sahamipoor
                                            need bios dell Inspiron 17 7000 2-in-1 p42e
                                            by sahamipoor
                                            hi...
                                            i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                                            i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                                            i updated to latest version and try other version but not working!
                                            service tag: HCQ3JW2
                                            i need your kind....
                                            10-01-2025, 11:10 AM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • GadgetsFix
                                            Dell Inspiron 16 5630 BIOS request
                                            by GadgetsFix
                                            I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                                            • Model: Dell Inspiron 16 5630
                                            • MainBoard Part Number: 4550SC01C004
                                            • Laptop Serial No: GKH3JX3
                                            • DP/N: 0303KM
                                            • QUAKE N RPL UMA CS MB
                                            • 213251-2
                                            • TMN0H$KB
                                            01-17-2025, 07:38 AM
