T560 bios needed!
  • chiefdome
    • May 2014
    • 6
    T560 bios needed!
    Hi there, a corrupted BIOS image of my lenovo T560.
    I am able to do a dump.
    But how can I obtain a valid BIOS image for this machine?
    I just wanted to change the wificard since then it doesn't boot no longer.
    There is just the post screen then it goes to a boot loop.
    I also have a dump from another board, so can I just replace the BIOS chip?
    No passwords are set.
    Thanks in advance!
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Thanks in advance!
    yes you can as long as same model and jsut chage the serail numebr later on
      SMDFlea commented
      Editing a comment
      And clean the ME firmware if its an intel model
    • 21219
    The wifi card will be whitelisted. Put the old card back in and see if it boots back up.Modding the bios or changing the card for a lenovo FRU approved card is the only way around it.Swapping the bios chip will not work
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • q2v5
      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
      by q2v5
      Lenovo T480s
      Model 20L8-S3TE00
      Board ET481-U10
      Chip MX25L12873F
      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
      08-15-2024, 10:40 PM
    • Neddsme
      Bios partially corrupted somehow and now warm boot doesn't work which is critical
      by Neddsme
      Hie.
      I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
      Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
      I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
      I managed to run Windows troubleshooting and...
      02-04-2022, 05:57 AM
    • Max029
      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
      by Max029
      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
      TY,
      08-18-2024, 08:28 PM
