HP Probook 635 Aero G7 Endpoint Security Controller Problem
  • Bios Cracker
    • Oct 2024
    • 315
    • India
    #61
    Originally posted by bamboofuto
    please help,
    SN# 5CG1163FWF
    came in dead, flash bios, done. a week later the customer said the laptop display bios update when turn on and after that dead no display. always show led 7 times on capslock.
    i have tried to flash the bios again and everything ok. but couple days later i got the same problem. when turn on it shows HP endpoint security controller problem. when click ok show bios update and dead no display again.
    can someone check the bios if there is a problem with it?
    Upload the firmware of the other bios chip.
    • bamboofuto
      • Nov 2022
      • 53
      • indonesia
      #62
      do you mean the EC chip firmware?
      • bamboofuto
        • Nov 2022
        • 53
        • indonesia
        #63
        i flashed the EC chip with the file that i attached and it turn on but on the other side MPM product information not valid. could someone help me?
        the serial number is 5CG1163FWF
        Don't post pictures unless asked..
        • shiyab
          • Sep 2023
          • 1366
          • india
          #64
          please help,
          SN# 5CG1163FWF
          hi try
          • shaddy254
            • Feb 2021
            • 27
            • kenya
            #65
            hello guys, any one there to assist with this
            ProdID:443V8PA#ABJ
            SN: 5CG1241VR0
            attatched main bios
            • danito
              • Jun 2016
              • 901
              • Romania
              #66
              ProdID:443V8PA#ABJ
              SN: 5CG1241VR0
              attatched main bios
              try
              • shaddy254
                • Feb 2021
                • 27
                • kenya
                #67
                Originally posted by danito
                try
                hello, tried this file but laptop doesn't boot. Charging light remain white.
                • shiyab
                  • Sep 2023
                  • 1366
                  • india
                  #68
                  hi try
                  • noname2024
                    • Aug 2024
                    • 222
                    • CỎ MỸ XỊN
                    #69
                    ProdID:443V8PA#ABJ
                    SN: 5CG1241VR0
                    attatched main bios
                    try
                    • xpy000
                      • Feb 2022
                      • 15
                      • Morocco
                      #70
                      Hi everyone. Can you please help with this laptop? Hp probook 635 aero G7. I think there is a problem with the bios. No matter what I do, it won't accept booting from usb and trying to boot from the original SSD gives the error Clock watchdog timeout. I am attaching the flash bin files of both bios chips. I would like to reprogram the bios.
                      ProID 2W8S0EA#ABF
                      SN: 5CG1152XFH
                      Board ID: LINDEN-6050A3147201-MB-A01 (A1)
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11700
                        #71
                        ProID 2W8S0EA#ABF
                        SN: 5CG1152XFH
                        HP ProBook 635 Aero G7 Notebook PC (2W8S0EA)
                        • xpy000
                          • Feb 2022
                          • 15
                          • Morocco
                          #72
                          Thank you very much. Just to confirm that the bios files worked perfectly. Though the issue still persists at least I ruled out the bios as the culprit
                          • fede77
                            Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                            by fede77
                            Notebook HP ProBook 450 G8
                            ProdID 2K8L1LT#AC8
                            Mother: DAX8QAMB8D0 REV D
                            The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                            03-10-2025, 07:12 AM
                          • jmp9155
                            i have hp probook 640 g4 stucks hp endpoint security controller
                            by jmp9155
                            accidentally after the upgrade to 1.28 suddenbly my i hp probook 640 g4 stucks hp endpoint security controller i already downgrade the bios to 1.15 still the same and again revert back to 1.28.
                            any solution for this issue?
                            07-09-2024, 06:23 AM
                          • kolebbk
                            HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                            by kolebbk
                            Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                            HP Endpoint Security Controller problem
                            there is a problem with the hp endpoint security controller on the unit
                            I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                            09-04-2024, 12:44 AM
                          • mego1974
                            HP Probook x360 435 G7 Endpoint Security Controller
                            by mego1974
                            Hello
                            i need help
                            I have a laptop HP Probook x360 435 G7 with bios password
                            I succed to remove the password with the RC toll and right now i have this mesage on the scren "HP Endpoint Security Controller Problem " "Please contact the HP.Inc to have the unit serviced".
                            I have read the both bios chips and i have posted a picture with the chips pozition.
                            Can anybody help me with intruction or look on the dump if something is wrong ?
                            Thanks in advance!!
                            Edit
                            Serial 5CG03947C4...
                            12-17-2023, 01:57 PM
                          • spider300
                            HP ProBook 430 G8 hp endpoint security controller problem
                            by spider300
                            please Help Me ... ProBook 430 G8
                            HP EndPoint Security Controller Problem...
                            07-11-2023, 08:40 AM
