HP Probook 635 Aero G7 Endpoint Security Controller Problem
  • Bios Cracker
    • Oct 2024
    • 311
    • India
    #61
    Originally posted by bamboofuto
    please help,
    SN# 5CG1163FWF
    came in dead, flash bios, done. a week later the customer said the laptop display bios update when turn on and after that dead no display. always show led 7 times on capslock.
    i have tried to flash the bios again and everything ok. but couple days later i got the same problem. when turn on it shows HP endpoint security controller problem. when click ok show bios update and dead no display again.
    can someone check the bios if there is a problem with it?
    Upload the firmware of the other bios chip.
    • bamboofuto
      • Nov 2022
      • 53
      • indonesia
      #62
      do you mean the EC chip firmware?
      • bamboofuto
        • Nov 2022
        • 53
        • indonesia
        #63
        i flashed the EC chip with the file that i attached and it turn on but on the other side MPM product information not valid. could someone help me?
        the serial number is 5CG1163FWF
        Don't post pictures unless asked..
        • shiyab
          • Sep 2023
          • 1271
          • india
          #64
          please help,
          SN# 5CG1163FWF
          hi try
          • shaddy254
            • Feb 2021
            • 27
            • kenya
            #65
            hello guys, any one there to assist with this
            ProdID:443V8PA#ABJ
            SN: 5CG1241VR0
            attatched main bios
            • danito
              • Jun 2016
              • 881
              • Romania
              #66
              ProdID:443V8PA#ABJ
              SN: 5CG1241VR0
              attatched main bios
              try
              • shaddy254
                • Feb 2021
                • 27
                • kenya
                #67
                thank you
                • fede77
                  Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                  by fede77
                  Notebook HP ProBook 450 G8
                  ProdID 2K8L1LT#AC8
                  Mother: DAX8QAMB8D0 REV D
                  The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                  03-10-2025, 07:12 AM
                • jmp9155
                  i have hp probook 640 g4 stucks hp endpoint security controller
                  by jmp9155
                  accidentally after the upgrade to 1.28 suddenbly my i hp probook 640 g4 stucks hp endpoint security controller i already downgrade the bios to 1.15 still the same and again revert back to 1.28.
                  any solution for this issue?
                  07-09-2024, 06:23 AM
                • kolebbk
                  HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                  by kolebbk
                  Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                  HP Endpoint Security Controller problem
                  there is a problem with the hp endpoint security controller on the unit
                  I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                  09-04-2024, 12:44 AM
                • mego1974
                  HP Probook x360 435 G7 Endpoint Security Controller
                  by mego1974
                  Hello
                  i need help
                  I have a laptop HP Probook x360 435 G7 with bios password
                  I succed to remove the password with the RC toll and right now i have this mesage on the scren "HP Endpoint Security Controller Problem " "Please contact the HP.Inc to have the unit serviced".
                  I have read the both bios chips and i have posted a picture with the chips pozition.
                  Can anybody help me with intruction or look on the dump if something is wrong ?
                  Thanks in advance!!
                  Edit
                  Serial 5CG03947C4...
                  12-17-2023, 01:57 PM
                • spider300
                  HP ProBook 430 G8 hp endpoint security controller problem
                  by spider300
                  please Help Me ... ProBook 430 G8
                  HP EndPoint Security Controller Problem...
                  07-11-2023, 08:40 AM
