Asus X205TA rev 2.0
  • bogivet
    • Aug 2015
    • 19
    • Serbia
    Asus X205TA rev 2.0
    Hello to everyone. I need help with my bios dump. Laptop can not start, only red light on second. Thanks.
    Motherboard Asus X205TA rev 2.0
  • crowntoy99
    • Oct 2012
    • 265
    • india
    Re: Asus X205TA rev 2.0
    try
      • 21457
      You must post the serial number ,as per the rules.
      • bogivet
        • Aug 2015
        • 19
        • Serbia
        I was try many dumps, and some of them working, but wifi don't work. This is stiker from my laptop, thanks.
        • Blaszow
          • Apr 2025
          • 10
          • Polska
          Can you upload one of the working ones?
          • peste
            • Dec 2016
            • 13200
            • ROMANIA
            post S/N, full name and model, motherboard model, etc.
            post the contents of the bios chip even if it is corrupted..
            • Blaszow
              • Apr 2025
              • 10
              • Polska
              Laptop turning on but no display, current sitting at 0.100A, no flowing, under thermal camera only CPU gets little bit hot (around 40C)
              Name and model: Asus x205t
              Serial number: F2NLBC066819099
              Motherboard: X205TA_mb REV.2.0
              • hoaca388
                Badcaps
                • Jan 2022
                • 12113
                ASUS EeeBook X205TA
                • Blaszow
                  • Apr 2025
                  • 10
                  • Polska
                  Originally posted by hoaca388
                  ASUS EeeBook X205TA
                  Thank you very much, it worked!
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • kodox
                    Asus ExpertBook B1400CB Bios Dump Needed
                    by kodox
                    need original bios dump, original bios has flashed by other technician before me.
                    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                    unit info:
                    Model: Asus ExpertBook B1400CBA-0711A1235U
                    S/N: R6NXNZ006657238
                    CN: 7F6F
                    Mainboard Code: B1500CBA R2.1...
                    08-16-2025, 12:20 PM
