Asus G834JZ BIOS need.
  • Maxim Skridonenko
    • Apr 2018
    • 17
    • Украина
    BIOS looking for
    ASUS G834JZ, 6050a3441301-mb-a02
    BM42ZMC01L8,NC52NRKD0001B2MB,G834JZ,60NR0D30-MB1110,200,A036BCD30C9F
    • 24316
    Re: Asus G834JZ BIOS need.
    Originally posted by Maxim Skridonenko
    BIOS looking for
    Post the bios backup if you have one.
    • Maxim Skridonenko
      • Apr 2018
      • 17
      • Украина
      the previous master was erased ...
      thank you, I found it and will share it
        • 24316
        Ok, thanks for sharing
        • wishes2022
          • Nov 2022
          • 38
          • china
          Thanks for sharing
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • ronaldopdias
            ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
            by ronaldopdias
            I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
            • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
            • BIOS file downloaded directly from the official ASUS support page.
            • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
            Issue:
            The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
            Because FlashBack didn’t work, I:
            • Removed the BIOS SPI IC from
            02-04-2026, 03:16 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
