Unlock SVP Lenovo Thinkpad T14 Gen2
  • speed488
    • 10
    Originally posted by anhbanxoi
    2KB EEPROM just for serial, model, bios password. Laptop still can turn on without those informations. You can later program it with U1 tool
    OK so that is it. This is why people focus around the MEC1503: because the BIOS password is saved there.
    But, from what you are saying, just replacing the MEC1503 with a blank one should work to unlock the unit?
    • TiagoNecer
      • Nov 2022
      • 11
      • Brasil
      #42
      I already tried to buy a new chip (blank) on aliexpress, I changed it and the board didn't turn on, I only did the test, trying once, has anyone ever managed to make this procedure work?
      • CJ Mangasep
        • Oct 2024
        • Philippines
        #43
        Hello, I am asking those who know a way to remove the supervisor/bios password for my laptop
        HTB40/HP4B0/HT5B1/HP5B1/HT4B2 NM-D353 Rev:1.0
        serial number: PF-3NA82Y
        type number: 20W5-S0NH00
        Should I do some kind of shorting the chips? In that case which one should i short?
        Or should i do some kind of programming?
        Thank you
        • peste
          peste commented
          Editing a comment
          post merged..
      • acedogblast
        • Feb 2023
        • 56
        Hello I can confirm that replacing MEC1503 chip with another from a laptop without SVP does work. You can see how I did it in my post here: https://www.badcaps.net/forum/troubl...-and-x13-gen-2
        • cgtec
          • Feb 2014
          • 56
          • France
          #45
          Originally posted by speed488
          The MEC has an EEPROM though.
          According to this: https://docs.nordicsemi.com/bundle/n...doc/index.html
          MEC152x is identical to MEC150x except for an enhanced Boot-ROM SPI loader.
          So we can take a look at the MEC152X datasheet: https://ww1.microchip.com/downloads/...S00003427A.pdf
          2K byte Internal EEPROM (MEC1523 Only) - Which should be present in the MEC1503 as well
          So is the password stored there?
          If it's the case, I was wondering if this approach would be a viable option:
          • Dump the BIOS
          • Patch the BIOS to skip password checking popup
          • Write the patched BIOS
          • Boot and set a new blank password
          • Write the original BIOS
          Am I missing or overlooking something?
          you can not path bios .... any more
          • cgtec
            • Feb 2014
            • 56
            • France
            #46
            Originally posted by Mudau
            Re: Unlock SVP Lenovo Thinkpad T14 Gen2
            I did try with Nm-d351 schematic and boardview to locate jtag, my board was nm-d352, these boards looks identical.
            it only read once(rt809f), then stopped reading chip due to low voltage(3v),
            the customer took the machine before i can add the 10k resistors for 3v.
            you can try it out maybe you can win.
            [Mod. Edit] Schematic and boardview -> https://www.badcaps.net/forum/showth...77#post1248377
            Reminder: rules and organization of this section
            https://www.badcaps.net/forum/showthread.php?t=117483
            to enable jtag need script . most work on this chip use SWD .....
            • santoslao
              • Apr 2017
              • 140
              • BZ
              #47
              Does anyone know this person or confirm that they are working this way?
              T14 Gen2 MEC1503 ▼
              Unlock Lenovo T14 Gen 2 ''MEC1503''
              • santoslao
                • Apr 2017
                • 140
                • BZ
                #48
                I talked to him and look what he said.
                • anhbanxoi
                  • Sep 2021
                  • 180
                  • VN
                  #49
                  Try replacing the MEC, take a bit longer time but it works.
                  • santoslao
                    • Apr 2017
                    • 140
                    • BZ
                    #50
                    In the comments, he says it's done via patch and claims there's no way to read it on the MEC1503, so I contacted him, and he says it's only possible with the equipment in hand.
                    It's impossible that to this day this information remains a top secret; no one sells it, and no one performs the procedure remotely, only by hand.
                    He claims it's a patch, and we already have a clue about that, if that's indeed the case.
                    • cgtec
                      • Feb 2014
                      • 56
                      • France
                      #51
                      If you want to try... without breaking your head. try espi I03 and shorted with gnd but there is time exact to short . so this is it ... this it the methode ....
                      • santoslao
                        • Apr 2017
                        • 140
                        • BZ
                        #52
                        I heard that this method doesn't work for this model. And it's very risky to kill the machine! I've already done it in other models like T14 gen1.
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 507
                          • somewhere in europe
                          #53
                          it is not risky... i tried this hundreds of times. not a single machine died
                          • santoslao
                            • Apr 2017
                            • 140
                            • BZ
                            #54
                            And some "T14 Gen 2 intel" that you tried worked?
                            • img1
                              • Aug 2015
                              • 24
                              • Earth
                              #55
                              Originally posted by mmccomputer
                              Is there a solution for the MEC1503?
                              Hi!
                              I found a video about MEC1503 and RT809H. I'll test it and reply back in the next few days or weeks when I get my hands on a ThinkPad X1 Carbon G9 (NM-D341).
                              https://youtu.be/QOw7NWO_6RM
                              • santoslao
                                • Apr 2017
                                • 140
                                • BZ
                                #56
                                Originally posted by img1
                                Hi!
                                In the description it says it's this model, but me honestly? I don't think it's MEC1503 that he's programming! It doesn't show from the beginning of the video, I believe it's just a video to have views! They say that to read or write in this MEC, it is necessary to have a 10k resistor at some points on the board.
                                • img1
                                  • Aug 2015
                                  • 24
                                  • Earth
                                  #57
                                  Good point.
                                  The MoBo in the video is seemingly the NM-D341 with MEC1503, which is the exact board of the TP X1 Carbon G9.
                                  The TP Carbon is on it's own way to me (the customer lives in another city and he 'll jump over sometime, but IDK when exactly), time will tell. JTAG jig is not a problem because I already made my custom one for MEC ECs (pullup resistors on the board, so not all the resistors soldering needed, just the mode selector) which I successfully used with some MEC16xxs before. So the hardware is ready by the time the TP Carbon arrives. Anyway, I would have tried it by myself because I have an RT809H on hand and it's worth a try. :-)
                                  • santoslao
                                    • Apr 2017
                                    • 140
                                    • BZ
                                    #58
                                    Good point.
                                    Really! I don't know this machine, so I clearly see the board model! When you have it in hand, please post the result, we look forward to seeing it happen.
                                    • img1
                                      • Aug 2015
                                      • 24
                                      • Earth
                                      #59
                                      Sure, this is why I mentioned. I'm excited too. :-)
                                      • cgtec
                                        • Feb 2014
                                        • 56
                                        • France
                                        #60
                                        Hi!
                                        is not MEC1503 its Mec1663 . the MEC15xx or 17xx come with efuse . otp JTAG/SWD disable . if you want enable jtag you need patch EC FW flash in SPI ..... and the EC FW is protected hash signature verification ECDSA if you have KEY you can do what you whant ... LPC_eSPI_I03 shorted with gnd not kill board ...
                                          Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-06-2024, 09:45 AM
                                          09-06-2024, 09:40 AM
                                        • Grafnus
                                          Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                                          by Grafnus
                                          Hey there,
                                          first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                                          So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                                          Specs:
                                          • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                                          • CPU, GPU, RAM work fine (not involved in the Problem)
                                          So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                                          Now I noticed...
                                          08-06-2025, 11:54 AM
