dead HP 250 G6
  • vpower
    • Sep 2022
    • 116
    • italy
    dead HP 250 G6
    Hi, I don't even know if the problem is bios related.
    It's a HP 250 G6 serial CND8117C44, it died during an update. The caps key is blinking 5 times slow and 3 times fast. Maybe it is a bios problem? I read a backup of the bios with my CH341 interface. I download and extracted bios exe file from HP support and I found 5x .BIN files (and 5x .SIG files) named 084D4 0832D 0832E 08328 and 08445. Which file is correct? I tried to flash every file but the there is no fix. I understand that maybe I need to program the serial number. Any advice?
    Thanks in advance! Sorry if this maybe isn't the correct forum section. I'm a noob.
    • 22097
    Re: dead HP 250 G6
    Post your corrupt bios backup, the original one.
    These threads by Vesko might help in future to ID the correct bios and extract it.
    https://www.badcaps.net/forum/showthread.php?t=122195
    [Guide] How to extract ready for programming dump from HP update executable file
    https://www.badcaps.net/forum/showthread.php?t=121948
    • vpower
      • Sep 2022
      • 116
      • italy
      Re: dead HP 250 G6
      this is the currupted file I read
      thank you
      • vpower
        • Sep 2022
        • 116
        • italy
        Re: dead HP 250 G6
        thank you very much, problem solved!
        • Christian0734
          • Nov 2020
          • 92
          • France
          Hello, the BIOS of an HP 250 G6 Motherboard: DKL50/CSL52 LA-E821P was corrupted following an update. When performing a clear CMOS, the message 'CMOS checksum invalid...' is displayed at startup, and then, when the computer restarts after pressing "F1", a black screen appears with a consumption of about 0.220 A.
          I followed the procedures: I backed up the computer's BIOS, then downloaded the update file for the latest BIOS available on the HP website and extracted the BIOS files. There are 5 different ones: 084D4.bin; 0832D.bin; 0832E.bin; 08328.bin; 08445.bin.
          Next, I tried to determine which one matched, but unfortunately, when I search with the hexadecimal editor to find it in my saved BIOS file, I cannot find $BID or BID.
          So far, I have tested 3 of the BIOS files contained in the manufacturer's archive, but the machine does not start. I no longer get the 'CMOS Checksum invalid...' message but a black screen with a consumption of about 0.220 A, which could indicate that the computer has started but displays nothing.
          What do you think? Attached is the backup of the computer's BIOS
          HP 250 G6
          Motherboard: DKL50/CSL52 LA-E821P Rev 1.0
          SN# CND7504J9M
          ProdID 2SX62EA#UUW​
          • Vesko356
            Vesko356 commented
            Editing a comment
            23.3 KB is not a good read obviously...
        • Christian0734
          • Nov 2020
          • 92
          • France
          HP 250 G6
          SN# CND7504J9M
          ProdID 2SX62EA#UUW​
          Unfortunately, regarding the BIOS, I couldn't get more than that and now it's too late because I've already erased the chip to write on it
          • mascalzonegran
            • May 2023
            • 7
            • Italy
            I've a HP 250 G6 with:
            1wy08eea#abz
            Intel i3-6006
            Integrated GPU
            M.B. csl50/csl52 la-e791p
            rev 2.0
            I tried to update the bios but after that the PC doesn't start anymore.
            No blink from caps lock.
            I tried to use Hp tool but nothing happens.
            I backed up the bios from he tool before updating and now I have 5 different .bin files, all 8.192KB in size.
            I have someone that can flash the chip for me but I don't know which file to give him to write, can someone give me some pointers please?
            Thankyou in adavance.
              • 22097
              Originally posted by mascalzonegran
              I backed up the bios from he tool before updating and now I have 5 different .bin files, all 8.192KB in size. ​
              Please post the laptop serial number -> https://www.badcaps.net/forum/troubl...before-posting
              With which tool and software version did you use to make the backups.Did you use a programmer clip ?.Post the backups in seperate zip/rar attachments
              • mascalzonegran
                • May 2023
                • 7
                • Italy
                SN# CND733759V
                I used the tool from HP (downloaded from HP https://support.hp.com/it-it/drivers...ber=cnd733759v) e this create 5 files when notebook was still working.
                After the update I downloaded the same file from HP and this create 5 files that seems the same.
                I upload the original ones.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12413
                  SN# CND733759V
                  This is not the original bios. The original bios is a file on your computer.
                  • mascalzonegran
                    • May 2023
                    • 7
                    • Italy
                    Any ideas of where it could be?
                    I can access the disk if you remember where is located.
                    Anyways, there isn't someone that can provide the original bios for this notebook?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12413
                      Do you have the original bios saved ? Otherwise you have to flash the file one at a time, there will be one compatible with your device.
                      • mascalzonegran
                        • May 2023
                        • 7
                        • Italy
                        At this point I think that I DON'T have a backup....
                        HP tools has created twice the same files.
                        I could try 5 times to write this bin and pray for a good response, but I feel good with an image of the backup.
                        I'm start to think that isn't normal that caps lock doesn't blink and the problem could be another one.
                          • 22097
                          Do you have an SPI programmer, how do you intend to program the chip.
                          • mascalzonegran
                            • May 2023
                            • 7
                            • Italy
                            A friend of mine has the programmer and says that can do this.
                            The real problem is that I think to have a backup but I don't, pretty sure a need a copy from another notebook with same features.
                            Searching on line someone says that I could try to upload the files attached below, once per time, because one of them could be the right one. Anyone know if it's correct?
                              • 22097
                              Get your friend to make a backup of your bios chip with his programmer,then post that backup here inside a zip or rar attachment and wait until someone posts a bios for you.
                              • mascalzonegran
                                • May 2023
                                • 7
                                • Italy
                                Ok, as soon as possible I'll ask him.
                                Thank you fow now and waiting for other solutions.
                                Happy Easter
                                • mascalzonegran
                                  • May 2023
                                  • 7
                                  • Italy
                                  Hello everyone.
                                  I attach the bios from the bios before re-writing.
                                  Checked the microcode on the other bios stored before the update and rewrite on bios chip and now the notebook (seems to) work.
                                  Thanks for the help!
                                  • jm.fischer
                                    • Feb 2021
                                    • 4
                                    • Ger,many
                                    Hello everyone!
                                    As some members have already reported, an official Windows 10 update also destroyed the BIOS of my HP250G6.
                                    I have read out the defective BIOS and now ask the forum members to correct the defective BIOS - if possible.
                                    HP 250 G6
                                    SN# CND8106CMR
                                    ProdID 3VJ6OES#ABD
                                    A photo of the motherboard label is attached.
                                    Thanks in advance.​
                                  • gr8blondino
                                    • May 2024
                                    • Malta
                                    Click image for larger version  Name:	3.jpg Views:	0 Size:	84.4 KB ID:	3279145
                                    Hello.
                                    I have similar problem. HP 250 G6 (dkl50/csl52 la-e821p) powers on but does not show logo and does not boot. Responds to keyboard and when any of active F keys are pressed it shows the bottom screen message saying what was pressed but does not move to the BIOS setup or BOOT device menu. I tried HP Bios recovery that finished succesfully but there still is no change and laptop does not posts. Any chance I can get this junk back to work? I do not have original BIOS dump. You guys are geniuses, please guide me!
                                    • to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                      by to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                      I have opened the laptop and identified the main BIOS chip...
                                      10-24-2025, 01:35 AM
                                    • lap-top123
                                      Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                      by lap-top123
                                      HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                      Hp Elitebook 850 G8
                                      ProdID 52W98EC#ABD
                                      SN# 5CG1458XQ7
                                      Mac-address #1: 84:14:4D:2C:4B:5B
                                      UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                      Mainboard : 6050A3216701-MB-A01(A1)
                                      08-20-2025, 07:28 AM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                    • maanee11
                                      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                      by maanee11
                                      Hello Everyone,
                                      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                      In the website, you can only see specs etc.
                                      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                      11-08-2025, 04:08 AM
                                    • m1ch43lzm
                                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                      by m1ch43lzm
                                      Hi everyone
                                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                      There's also an extra OTP Secu.R...
                                      09-06-2025, 05:47 PM
