HP 15s-gr002au LA-H32AP REV 1.0 bios language
  • Stunt
    • Oct 2019
    • 195
    • South Africa
    Hi guys i've got HP_15s-gr002au ( AMD Processor )
    Board number - LA-H32AP REV 1.0
    S/N - CND0273V9W
    BID - 087D1
    It's working fine but the problem is when i boot to bios the bios settings
    is written in Chinese. So i googled how to change language in bios settings.
    I got the results for hp i have to boot to bios settings and press f8 and the pop up menu will appear to change language. But in my case when i press f8 nothing happens no pop up menu appears. Now i don't know what to do. If there's anyone who can help me and fix my bios and change the language to english i would be grateful
    Last edited by Vesko356; 10-05-2023, 02:04 PM. Reason: HP 15s-gr002au to thread title
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: LA-H32AP REV 1.0 bios language
    S/N - CND0273V9W
    BID - 087D1
    https://www.badcaps.net/forum/showthread.php?t=103526
    6. Finding bios update packages
    6.1.8 HP
    See:
    [Guide] How to extract ready for programming dump from HP update executable file
    https://www.badcaps.net/forum/showthread.php?t=121948
    https://www.badcaps.net/forum/showth...51#post1261151
    Originally posted by SMDFlea
    When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
    DMI and Win key: 61000 - 63FFF
    Become a Badcaps supporter
    Thanks to all supporters.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • eltano4i20
      [HELP] SAMSUNG NP270E4E-K01AR
      by eltano4i20
      1) Error trying to enter the BIOS
      --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
      Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
      BOOT PRIORITY ORDER (img-05)
      1- Windows Boot Manager
      2- SATA HDD
      3- NETWORK
      4- Debian
      2) Error trying to access the BOOT MENU
      --> I restarted the notebook and pressed [F10] but the BOOT...
      07-04-2025, 12:39 AM
