GM7MG7P No boot only backlight, need bios
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    help for this notebook gamming it has no brands it is intel i7 10gen with nvidia geforce rtx. After 10 seconds, only the backlight and the fans turn on but nothing is displayed. The board part number is mbpgm7mg7c-pp10.
    no signal on external hdmi port.
    Information is only on board GM7MG7P10T02205210051 a battery P/N PFIDG-00-13-3S2P-0
    I attach the original bios
    Thank
    Fabrizio
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: GM7MG7P No boot only backlight, need bios
    Thank
    Fabrizio
    I think the Laptop model is "TongFang GM7MG7P".
    You can try this file and see if it will help you or not.
    all donations are welcome,
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      I tried to update the bios but nothing changed when turned on the fans start then turn off after a while the backlight comes on. The heatsink gets hot and sometimes the fans spin but always just the backlight. It's probably the graphics chip
      • egelaptop
        • Jun 2015
        • 125
        • türkiye
        gm7mg7p rev 1.0 original file is missing, I need a file that I can try, can you help me?
          SMDFlea commented
          Editing a comment
          Have you read the whole thread.. try the bios at post 2
      • egelaptop
        • Jun 2015
        • 125
        • türkiye
        The file in the 2nd message did not work, I wanted to ask if there was another file I could try.​
        • husnu16
          • Jun 2020
          • 120
          • Türkiye
          Hello dear masters.
          Monster Tulpar T5 V20.2
          gm7mg7p mb v1.0
          We changed the PCH on this device and then performed BIOS Me clean.
          The device worked and turned on quickly, but no sound output was detected. All devices work with the original bios, but I get a delayed display.
          What am I missing here?
          Why does the audio device cause problems after Me clean?
          On a different Acer 11 generation device, it did not see ethernet after me clean. Can you help me understand why?
          Thank you all.
          I'm attaching the original dump.
          • SoporteNetFe
            • Aug 2021
            • 121
            • Argentina
            Maybe this can help you.
            • husnu16
              • Jun 2020
              • 120
              • Türkiye
              Hello, I tried to install this update package but it was not successful. Thanks for your help anyway.
              • SoporteNetFe
                • Aug 2021
                • 121
                • Argentina
                You try flash GMxMGxxN109MON07.BIN ?
                • husnu16
                  • Jun 2020
                  • 120
                  • Türkiye
                  The dump you mentioned is 13mb, I don't think flashing it will work.
                  • volinakis
                    • Jan 2021
                    • 2872
                    • N/A
                    try
                    • husnu16
                      • Jun 2020
                      • 120
                      • Türkiye
                      Originally posted by volinakis
                      try
                      It worked perfectly. Thank you.
                      Gm7mg7p rev 1.0
                      • volinakis
                        • Jan 2021
                        • 2872
                        • N/A
                        Gm7mg7p rev 1.0
                        you are welcome
                        • SoporteNetFe
                          • Aug 2021
                          • 121
                          • Argentina
                          BIOS\GM5MG0O\FlashUtil\Fpt\GMxMGxxN109MON07.BIN ? 16.384 kb
                          • volinakis
                            • Jan 2021
                            • 2872
                            • N/A
                            is only Bios Region, not entire bios.
                            • kenkaniff
                              HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                              by kenkaniff
                              Product Name: HP Pro x360 Fortis 11-inch G9
                              System BIOS: U94 Ver.01.08.00 10/06/2023
                              Serial Number: 5CG31946F5
                              SKU Number: 85W05EC#AK8
                              Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                              This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                              I needed to remove bios password...
                              10-01-2025, 04:32 AM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • q2v5
                              Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                              by q2v5
                              Lenovo T480s
                              Model 20L8-S3TE00
                              Board ET481-U10
                              Chip MX25L12873F
                              Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                              2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                              The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                              08-15-2024, 10:40 PM
                            • Neddsme
                              Bios partially corrupted somehow and now warm boot doesn't work which is critical
                              by Neddsme
                              Hie.
                              I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                              Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                              I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                              I managed to run Windows troubleshooting and...
                              02-04-2022, 05:57 AM
                            • Max029
                              Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                              by Max029
                              I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                              I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                              TY,
                              08-18-2024, 08:28 PM
