ThinkBook 14 G3 ACL BIOS BIN
  • trepachka
    • Oct 2022
    • 457
    I have this ThinkBook 14 G3 ACL notebook. Upon powering it on, the power button, ESC key and CAPS LOCK light up, computer draws 0.6A without the battery, fans start spinning but there is no video and no other keyboard keys light up. I suspect the BIOS is bricked.
    The BIOS chip is Winbond 74M25JWEIQ which is read by CH341A programmer as W25JV chip @ 256 Bit/32Mb/1.8V without any issues. The BIN file is below.
    Can someone, please help me fix the BIOS file? Thank you.
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: ThinkBook 14 G3 ACL BIOS BIN
    Virgin BIOS with your DMI and Windows Key.
    Serial Number: MP26MDDM.
    all donations are welcome,
    • trepachka
      • Oct 2022
      • 457
      Thank you. Worked immediately after re-flash. I wish I could buy you a beer.
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        You're welcome.
        This is not allowed here, but you can still donate to the forum if you want to.
        • Negoti8
          • Aug 2023
          • 26
          Question here. I'm also using the ch341a programmer. Seems to read the windbond 32mb 256bit fine but refuses to wright to it. Is there limitations to this programmer or is it my fault for doing it at 3.3v without the 1.8v adaptor. 25q256jveq chip from hp board.
          • hardware1
            • Sep 2021
            • 2949
            • N/A
            25Q256JV is 3.3v chip there is no need to use 1.8v adapter.
            You should use NeoProgrammer software, de-solder the chip from the board (Don't use a clip) and press verify after flashing the chip.
            • Negoti8
              • Aug 2023
              • 26
              As you mentioned above I am currently doing. Neoprogrammer said it write to the chip but when doing verify I get an error and then reading chip again it reads as a blank.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Erase the chip before programming.
                Become a Badcaps supporter
                Thanks to all supporters.​
                • Negoti8
                  • Aug 2023
                  • 26
                  Refuses to erase. I think might be bad, don't know how though
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    You are programming the chip inside the motherboard using a clip?
                    • Negoti8
                      • Aug 2023
                      • 26
                      No soldered to a wson8 to dip8 adaptor pugged into the ch431a
                      • hardware1
                        • Sep 2021
                        • 2949
                        • N/A
                        It could be a problem with the chip, the adapter or the programmer itself.
                        • BOSSLIN
                          • May 2024
                          • china
                          Thank you.
                          • joemateo
                            • Jul 2016
                            • 6
                            • ecuador
                            thanks friend bios ok
                            • hardware1
                              • Sep 2021
                              • 2949
                              • N/A
                              Great, you're welcome.
                              • to5it0
                                by to5it0
                                10-24-2025, 01:35 AM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                08-05-2025, 05:12 AM
                              • maanee11
                                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                by maanee11
                                Hello Everyone,
                                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                In the website, you can only see specs etc.
                                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                11-08-2025, 04:08 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                Hi everyone
                                09-06-2025, 05:47 PM
                              • Forest79
                                by Forest79
                                07-23-2023, 07:39 AM
