HP Elitebook 850 G8 Bios unlock
 I need a clean BIOS for HP Elitebook 850-G8
 SN : 5CD114FPWC . The attached one is corrupt, boot is stuck on Hp Sure Start Recovery Loop
 Thank on advanceAttached FilesEmeriComment
 Last edited by SMDFlea; 09-12-2025, 11:36 AM. Reason: edited. No need to post the same bios again...EmeriComment
 I'm lost since RCUnlock doesn't seem to support 32mb dumps. I'm trying to remove the BIOS password.
 I have attached the dumps from both the front (BIOS?) chip and back (EC?) chip, both 32mb.
 I'm confused as to which one does what, and which to flash.
 Some items show up in yellow or red in UEFITool. Unsure if that's important or means anything.
 Here is laptop info:
 HP Elitebook 850 G8
 Serial Number
 5CG2136LGT
 Product ID
 1G1X8AV
 SKU Number
 1G1X8AV
 Feature Byte
 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfPgSguhKjhk8mEmVmwn7nVngpDpq.Aq
 I have access to the BCU GetConfig file if that's any use.
 Any help appreciated!Comment
 Any luck?Hi,
 HP Elitebook 850 G8
 Serial Number
 5CG2136LGT
 Product ID
 1G1X8AV
 SKU Number
 1G1X8AV
 Feature Byte
 Yes.Attached Files↵
 https://www.badcaps.net/donateComment
 HP EliteBook x360 830 G8
 ProID 17N22AV
 SN 5CG3275LNS
 Feature Byte:
 476J6S6b7B7H7M7R7W7maBaEapaqauawbVcAd 6eMfPfXgSguhKjhk8mEmVn7nVngpDpnpqpr.YA
 Build ID: 21WWOPEZ601#SUUN#DUUN
 It has an MDM lock. If anyone can help, many thanksComment
 TryAttached Files↵
 I previously took a BIOS chip from another laptop of the same model and tested it there, and most likely the EC is also faulty.
 This laptop has a company lock. After connecting to the internet, I have to enter the company email or the security password.
 Thanks a lot
 I have flashed your file onto the rear chip, and left the front BIOS chip as is.
 The screen stays black on boot, and the capslock and NumLock flash white 7 times.
 The laptop doesn't boot. I have tried AC only, etc..
 Do I need to flash the front BIOS chip too?
 Kind regardsComment
 Try it
 After Flash Patched File, in First BOOT got to setup restore Factory defaults and save and exit flash back Original BiosComment
 Kind regards
 Possible to take another look at it please?
 Thank you!Comment
 Elitebook 850 G8
 SN = 5CG1300T63
 6050A3216701 MB A01 (A1)
 Remove bios password(IGNORE THE BACKUP NAMING, should be 850 G8)Attached FilesComment
							Channel: BIOS Requests ONLY!
			by WutruHi guys,
 If someone would be able to provide some expertise, I'd be very grateful.
 BIOS Corruption - Cause
 So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
 After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
			by STKR123Greetings badcaps community,
 I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
 So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
 Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
 I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
 These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
 I learned that desoldering...10-29-2024, 06:03 AM
			by macabookHello everyone,
 🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
 07-24-2025, 02:17 PM
			by clrscrplease help me unlock bios password hp elitebook 835 G11
 S/N: 5CG50434RD
 thanks!...-
- Loading...
