HP Elitebook 850 G8 Bios unlock
  • Quin TeknoLife
    • Mar 2024
    • 21
    • the Netherlands
    Originally posted by hoaca388
    Unlocked
    Flashed and assembled the laptop but sadly just caps/num blinking 7 times, what should I do? Could this mean bad connection/misaligned chip?
    • hoaca388
      Badcaps
      • Jan 2022
      • 11313
      • Viet Nam
      Flash the original file again, if it doesn't work, you accidentally damaged your device.
      • volcour
        • Dec 2015
        • 86
        • algiria
        hello
        I need to write Feature Byte in main bios unlock
      • rex98
        • Feb 2023
        • 1240
        • Mandaue CEBU, Philippines
        Originally posted by volcour
        hello
        all your bios posted above has no feature byte. if you still have the original dump kindly upload here and also your serial number.
        original dump not the ones you messed up.
        • miansh621
          Banned
          • May 2022
          • 133
          • pakistan
          3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPhKhkjhk8.BQ
          write this featurbyte
          • THEDUDE
            • Sep 2010
            • 20
            #26
            Hi , I need bios unlocked for password and endpoint security please .
            hp elitebook 850 G8
            s/n 5CG2090TWX
            MB 6050A3216701-MB-A01(A1)
            Thank's
            • minhdigital
              • Nov 2022
              • 725
              • Vietnam
              #27
              hp elitebook 850 G8
              s/n 5CG2090TWX
              Thank's
              Send to you
              • rex98
                • Feb 2023
                • 1240
                #28
                hp elitebook 850 G8
                s/n 5CG2090TWX
                Thank's
                only flash this main do not touch the EC.
                First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults and exit.
                Use BCU to fill these DMI info. you can permanently disable absolute in BCU
                Serial Number: 5CG2090TWX
                Product Number: 1G1X8AV
                CT Number: PKPSH00WBGC40S
                Description: HP EliteBook 850 G8 Notebook
                build_id: 21WWCVCT602#SABU#DABU
                Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAdUdpdqeMfPgSguhKjhk8mEmVmwn7nVngpD.t3
                MAC Address: A8-B1-3B-5C-4C-C1​
                • THEDUDE
                  • Sep 2010
                  • 20
                  #29
                  Amazing Thanks, super fast appreciated.......and for the patched file cheers rex
                  • volcour
                    • Dec 2015
                    • 86
                    • algiria
                    #30
                    motherboard 6050A3216701-MB-A01 (A1)
                    Click image for larger version  Name:	photo_2024-04-04_06-03-49.jpg Views:	0 Size:	192.4 KB ID:	3247298
                    • rex98
                      • Feb 2023
                      • 1240
                      #31
                      Serial Number: 5CG24209JN
                      Product Number: 5P5X3EA#UUZ
                      CT Number: PKPSF00WBH905M
                      build_id: 21WWCVDZ603#SUUZ#DUUZ
                      Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAeMfAfPgSguhKjhk8mEmGmVmwn7nVngpnpppqpr.nF
                      MAC Address: 38-CA-84-D7-58-11
                      • THEDUDE
                        • Sep 2010
                        • 20
                        #32
                        Sorry i am a bit lost do i reflash the main bios with this ? Thanks for the help.
                        • volcour
                          • Dec 2015
                          • 86
                          • algiria
                          #33
                          MAC Address: 38-CA-84-D7-58-11​
                          It works thank you
                          • THEDUDE
                            • Sep 2010
                            • 20
                            #34
                            Hi , i have another bios locked with password and security, Thanks in advance
                            HP EliteBook 850 G8
                            S/N 5CG2090TQG
                            M/B 6050A3216701 -MB-A01(A1)
                            • qayyum786
                              • Aug 2018
                              • 1933
                              • INDIA
                              #35
                              HP EliteBook 850 G8
                              S/N 5CG2090TQG
                              Where is the dump ?
                              • THEDUDE
                                • Sep 2010
                                • 20
                                #36
                                Originally posted by qayyum786
                                Where is the dump ?
                                sorry rushing around. here we go and Thanks again.
                                • rex98
                                  • Feb 2023
                                  • 1240
                                  #37
                                  Serial Number: 5CG2090TQG
                                  CT Number: PKPSH00WBGC415
                                  BuildID: 21WWCVCT602#SABU#DABU
                                  MAC Address : A8:B1:3B:5C:4C:FB​
                                  • THEDUDE
                                    • Sep 2010
                                    • 20
                                    #38
                                    Awesome again super quick really appreciated. Thank you
                                    is this just the password as it has the end point security on this laptop. still new to this.
                                    I still have the wolf security showing up at the start everything else works great , anyway of getting rid of the wolf security.? Thanks
                                    • Olegg456
                                      • Aug 2023
                                      • 3
                                      • poznan
                                      #39
                                      hey i want unlock my bios on hp 850 g8 who can help me?
                                      DUMP
                                    • Olegg456
                                      • Aug 2023
                                      • 3
                                      • poznan
                                      #40
                                      DUMP
                                      hello you can help me delete computrace ? password deleted with rcunlocker but absolute not deleted SN 5CG2421GIG
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • STKR123
                                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                        by STKR123
                                        Greetings badcaps community,
                                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                        I learned that desoldering...
                                        10-29-2024, 06:03 AM
                                      • clrscr
                                        Need unlock bios hp elitebook 835 G11
                                        by clrscr
                                        please help me unlock bios password hp elitebook 835 G11
                                        S/N: 5CG50434RD
                                        thanks!...
                                        06-04-2025, 09:38 PM
                                      • Guest
                                        Elitebook 850 G5 BIOS bricked
                                        by Guest
                                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                        I assume the BIOS update failed, so I searched for the BIOS chip.
                                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                        Can the corrupted...
                                        03-24-2025, 01:21 AM
                                      • Bharath Ram
                                        HP Elitebook MT45 Bios Unlock
                                        by Bharath Ram
                                        Hi
                                        Can someone please unlock the attached bios file
                                        Laptop: HP MT45
                                        Chip: W25Q256JV
                                        Thanks...
                                        06-21-2025, 09:09 PM
