Hp elitebook 840 g9
  • Dan20701
    • Sep 2020
    • 192
    • United Kingdom
    #81
    After two days of messing around I finally figured it out, I no longer need help with my last post.
    Thanks.
    • maximilianus
      • May 2024
      • 9
      • Austria
      #82
      Need reset BIOS Administrator Password on the HP G9 840
      Can it be read using the program or must the flash chip be desoldered? ?
      Does anyone know which BIOS flash chip is in the G9 ?
      the laptop works
      When I enter the bios and want to make settings, it asks for a BIOS Administrator Password
      • peste
        • Dec 2016
        • 12230
        • ROMANIA
        #83
        the laptop works
        You have to remove the chip from the motherboard...a video as an example..
        https://www.youtube.com/watch?v=DWWigscuQDY
        • magna1984
          • Jun 2024
          • 5
          HP Elitebook 840 G9
          SN#5CG30121VX
          6050A3417601-MB-A01
          Please help me with bios password removal.
          Thank you.
          • alfredposadas09
            • Aug 2020
            • 342
            • Philippines
            #85
            Originally posted by magna1984
            HP Elitebook 840 G9
            SN#5CG30121VX
            6050A3417601-MB-A01
            Thank you.
            here is your unlocked file
            VERY IMPORTANT STEPS
            1. GO TO BIOS AT FIRST BOOT (F10)
            2. APPLY FACTORY DEFAULT SETUP
            3. GIVING ME FEEDBACK IF IT WORKS MAKES ME HAPPY TO HELP MORE
            • maximilianus
              • May 2024
              • 9
              • Austria
              #86
              What is the chip mark on the G9 840?
              I want to know which programmer CH341A​ adapter i need
              • alfredposadas09
                • Aug 2020
                • 342
                • Philippines
                #87
                mostly the chip is beside in the ram get it via DESOLDERING THE CHIP make sure to back up 4x since your programmer is not a good programmer
                • magna1984
                  • Jun 2024
                  • 5
                  Thank you so much. Password removed . Put all laptop information in. Only left "Cirrus Discrete Amp Calibration Data" , found some posts about. If you know easy way , please let me know .
                  • alfredposadas09
                    • Aug 2020
                    • 342
                    • Philippines
                    #89
                    just flash the original bios again
                    • ingenieroedu
                      • May 2023
                      • 61
                      • Colombia
                      #90
                      Hello, can anyone remove the password?
                      hp Elitebook 840 G9
                      with plate number: 6050A3417601 mb A01
                      sn/ 5CG3073T4G​
                      • rex98
                        • Feb 2023
                        • 1235
                        • Mandaue CEBU, Philippines
                        #91
                        hp Elitebook 840 G9
                        sn/ 5CG3073T4G
                        first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                        use BCU. you can permanently disable Absolute lock in BCU.
                        here's your DMI:
                        Serial Number: 5CG3073T4G
                        Product #/SKU: 692G6LT#ABM
                        CT Number: PQSPR00WBHQ2DV
                        Description: HP EliteBook 840 14 inch G9
                        BuildID: 22WWWPAT602#SABM#DABM
                        Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPgSguhKjhk8mEn7nVngnwpTpqqjqz.ft
                        MAC Address : 7C:4D:8F:EF:E8:0F​
                        • ingenieroedu
                          • May 2023
                          • 61
                          • Colombia
                          #92
                          here's your DMI:
                          Thank you, it worked at first, it took a while to show the screen, then it gave me a bit of a problem with the cirrus code, but I was able to solve it, very grateful.
                          • ingenieroedu
                            • May 2023
                            • 61
                            • Colombia
                            #93
                            [CITA = rex98; N3284856]
                            here's your DMI:
                            time I have a problem, it starts up, shows the first screen, then it restarts and at that point it starts up, it's a little slow. I thought it might be an update, but it won't let me update the Intel Management Engine and also gives me a problem with an Intel Smart Sound Technology OED driver. Now sorry for my ignorance but it seems to be a ME region issue but I don't know if these 12 gen Intels can clear that region any help with this error
                            • ingenieroedu
                              • May 2023
                              • 61
                              • Colombia
                              #94
                              This is the problem that I am having when updating the bios. Maybe you can help me. Now, it has the SPI chip that is next to the ram memories and it has 2 others, one near the USB ports and another next to the nuvaton but I only extracted the SPI ones so if another one is required, let me know thank you very much hp Elitebook 840 G9 SPI.rar
                              • rex98
                                • Feb 2023
                                • 1235
                                #95
                                This is the problem that I am having when updating the bios. Maybe you can help me. Now, it has the SPI chip that is next to the ram memories and it has 2 others, one near the USB ports and another next to the nuvaton but I only extracted the SPI ones so if another one is required, let me know thank you very much [ATTACH]n3285398[/ATTACH]
                                flash again your original dump. it should work without password.
                                • ingenieroedu
                                  • May 2023
                                  • 61
                                  • Colombia
                                  #96
                                  How well all the problems are solved, working at 100%, very grateful
                                  • magna1984
                                    • Jun 2024
                                    • 5
                                    Works for me as well. Thanks a lot.
                                    • maximilianus
                                      • May 2024
                                      • 9
                                      • Austria
                                      #98
                                      Please remove BIOS Administrator Password
                                      hp Elitebook 840 G9
                                      Build ID : 22WWWPBZ602#SABU#DABU
                                      sn/ 5CG3124DQ4
                                      • maximilianus
                                        • May 2024
                                        • 9
                                        • Austria
                                        #99
                                        There are two G9 BIOS 25XXX. One on the front and one on the back of the motherboard (when the board is removed and flipped over).
                                        I read this one from the other side.
                                        The small CH361A works well with the new chips with the AsProgrammer.​
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11150
                                          • Viet Nam
                                          #100
                                          Post main bios.
                                          Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
