Asus Tuf fx706hcb bios
  • noname2024
    • Aug 2024
    • 243
    • CỎ MỸ XỊN
    Originally posted by joshAU
    Can someone tell me what the password is from this BIN file?
    Model number is Asus FX706H.
    Serial number is NANRCXARR012423.
    Printed on the mainboard is DANJJMB1AA0 REV A.
    The file was read with a CH341A black programmer using the NeoProgrammer 2.2.0.10 software and then zipped so it could be uploaded.
    The chip did not detect correctly, but it seems to have been read and verifies OK after setting it as a W25Q128JV.
    The correct model on the chip itself is 25R128JV.
    Any help greatly appreciated, and a merry Christmas to all.
    try
    • minhdigital
      • Nov 2022
      • 753
      • Vietnam
      Try
      • shiyab
        • Sep 2023
        • 1476
        • india
        Boot Password : SSS777
        ​hi try
        • joshAU
          • Oct 2008
          • 35
          Thank you, noname2024 and minhdigital for the modified BIN files.
          Thank you also shiyab​ for the actual password!
          I will try the password first when I am back in front of the PC next Monday and update.
          If not, I will remove the BIOS chip and reflash it with one of the above two BIN files.
          Thank you all, once again, much appreciated, and a merry Christmas to all!
          • joshAU
            • Oct 2008
            • 35
            Just a quick update....
            Thanks again shiyab​.
            The password you provided worked!
            Much appreciated
            Do you have to decode or decrypt the password from the bin file, or run it through an algorithm?
            I know, a long time ago, the IBM Thinkpad BIOSes used to store their admin passwords as MF1 scancode, but I am not familiar with more recent ones.
            Anyway, thanks again.
            • pityulix
              • Nov 2021
              • 28
              • Targu-Mures
              #26
              Hi Folks,can i ask for a bios cleaning or inspection?,laptop starting but no capslock,no fan spinning.Thanks in advance.
              Laptop is:
              ASUS TUF FX706HC-HX007W
              SN: MBNRCX06H683487
              CN: DDH5 24M
              MotherBoard: DANJJMB1AA0 Rev:A
              • shiyab
                • Sep 2023
                • 1476
                • india
                #27
                Laptop is:
                SN: MBNRCX06H683487
                CN: DDH5 24M
                hi try
                • pityulix
                  • Nov 2021
                  • 28
                  • Targu-Mures
                  #28
                  Originally posted by shiyab
                  hi try
                  I tried it,doing the same,the chipset might be dead,but i have no short anywhere,all voltages present,but not at CPU.Current is 7-17mA on standby.I think its not bios.I have to investigate further,thank you.I return if need further help on bios,i might need to change PCH or EC.
                  • bozdag
                    • 10
                    • nederland
                    #29
                    FX706HCB-HX152W SN:N1NRCX05P86703G
                    it died while updating the bios,the file seems corrupt
                    • danito
                      • Jun 2016
                      • 939
                      • Romania
                      #30
                      this is not the chip. something with 128 aka W25Q128
                      • volinakis
                        • Jan 2021
                        • 2733
                        • N/A
                        #31
                        that's not bios chipset , see pic. Read it without ISP when you choose chipset in RT809
                        • bozdag
                          • 10
                          • nederland
                          #32
                          Thanks, it seems like the file is corrupt or I didn't quite understand it.
                          • shiyab
                            • Sep 2023
                            • 1476
                            • india
                            #33
                            hi try
                            • bozdag
                              • 10
                              • nederland
                              #34
                              Thank you, everything is fine and working normally
                              • ioan.onutu
                                • Apr 2023
                                • 7
                                • Romania
                                #35
                                I have an ASUS FX706HCB-HX154 laptop that powers on (power LED only), but:
                                • Black screen
                                • No keyboard response
                                • Fan doesn’t spin
                                • Voltages seem fine
                                I suspect a corrupted BIOS or ME region issue. Can someone help with a working dump or a cleaned BIOS (ME clean)?
                                Original BIOS dump is attached.
                                Label info:
                                Model: FX706HCB-HX154
                                SN: MANRCX02N58442G
                                CN: NT4T
                                MFD: 2021-10
                                Thanks in advance!
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11736
                                  #36
                                  • Black screen
                                  • Fan doesn’t spin
                                  Label info:
                                  SN: MANRCX02N58442G
                                  CN: NT4T
                                  MFD: 2021-10
                                  Thanks in advance!
                                  FX706HCB
                                  • ioan.onutu
                                    • Apr 2023
                                    • 7
                                    • Romania
                                    #37
                                    Originally posted by hoaca388
                                    FX706HCB
                                    Thanks a lot for taking the time to send me the BIOS dump — I really appreciate it!
                                    Unfortunately, it didn't work on my board. It might not be fully compatible with my hardware, or the issue lies elsewhere. Still, thank you again for your help!
