Asus Tuf fx706hcb bios
Can someone tell me what the password is from this BIN file?
Model number is Asus FX706H.
Serial number is NANRCXARR012423.
Printed on the mainboard is DANJJMB1AA0 REV A.
The file was read with a CH341A black programmer using the NeoProgrammer 2.2.0.10 software and then zipped so it could be uploaded.
The chip did not detect correctly, but it seems to have been read and verifies OK after setting it as a W25Q128JV.
The correct model on the chip itself is 25R128JV.
Any help greatly appreciated, and a merry Christmas to all.Attached FilesComment
hi tryComment
Thank you, noname2024 and minhdigital for the modified BIN files.
Thank you also shiyab for the actual password!
I will try the password first when I am back in front of the PC next Monday and update.
If not, I will remove the BIOS chip and reflash it with one of the above two BIN files.
Thank you all, once again, much appreciated, and a merry Christmas to all!Comment
Just a quick update....
Thanks again shiyab.
The password you provided worked!
Much appreciated
Do you have to decode or decrypt the password from the bin file, or run it through an algorithm?
I know, a long time ago, the IBM Thinkpad BIOSes used to store their admin passwords as MF1 scancode, but I am not familiar with more recent ones.
Anyway, thanks again.
Hi Folks,can i ask for a bios cleaning or inspection?,laptop starting but no capslock,no fan spinning.Thanks in advance.
Laptop is:
ASUS TUF FX706HC-HX007W
SN: MBNRCX06H683487
CN: DDH5 24M
MotherBoard: DANJJMB1AA0 Rev:A
I tried it,doing the same,the chipset might be dead,but i have no short anywhere,all voltages present,but not at CPU.Current is 7-17mA on standby.I think its not bios.I have to investigate further,thank you.I return if need further help on bios,i might need to change PCH or EC.Comment
FX706HCB-HX152W SN:N1NRCX05P86703G
it died while updating the bios,the file seems corruptComment
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thanks, it seems like the file is corrupt or I didn't quite understand it.Attached FilesComment
I have an ASUS FX706HCB-HX154 laptop that powers on (power LED only), but:- Black screen
- No keyboard response
- Fan doesn’t spin
- Voltages seem fine
I suspect a corrupted BIOS or ME region issue. Can someone help with a working dump or a cleaned BIOS (ME clean)?
Original BIOS dump is attached.
Label info:
Model: FX706HCB-HX154
SN: MANRCX02N58442G
CN: NT4T
MFD: 2021-10
Thanks in advance!
- Fan doesn’t spin
Label info:
SN: MANRCX02N58442G
CN: NT4T
MFD: 2021-10
Thanks in advance!Attached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
Channel: BIOS Requests ONLY!
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by badalasus all in one a3402wba bios password remove plz
model and sl no
mb part no attached
old bios with password attached...-
- Loading...
