Hi Guys, Pls Need bios dump HP Zbook Fury 17 G7 LA-J203P EC & Main
Re: Need bios dump HP Zbook Fury 17 G7 LA-J203P
always when you make a request for bios, post the original bios even if it is corrupted.. the full name and model, the S/N... etc...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs. -
sry i have just one file check and raportAttached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
laptop started with black screen. After repair the BIOS (ver.01.04) and upgrade to latest ver. 01.20.00 the Endpoint Security Controller Problem occured.
I've tried to fixe this error but after programming it's still active
CND1105QRY
Fix this bug please.
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Thanks SMDFlea
Endpoint Security Controller problem disappeared.
MB run in Manufacturing Programming Mode, after DMI/ID data BCU complete everything works fine.
Good day
Please Help CLEAR ME this file
HP ZBOOK FURY 17 G7
SN CND0475D20
FAULT: Late display
by AhariHi all,
I...-
by harounHDneed clear me bios for hp zbook fury 17 g7
serial number CND1273QQ4...-
Channel: BIOS Requests ONLY!
by zlr8rGreetings
I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
Serial Number: 5CG3202C16
Product #/SKU: 739P0AV
CT Number: PRTUE00WBI30YX
Description: HP ZBook Firefly 14 inch G10
BuildID: 23WWWGAZ602#SABU#DABU
Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
MAC address not found.- I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
