lease friends, fix this bios, the laptop doesn't display, I've tried to clean me region but the result is still the same, I don't know how to extract files from the official Dell website, thank you
please friend fix this bios dell m14-r4 no display psu 2ma thank you
Re: please friend fix this bios dell m14-r4 no display psu 2ma thank you
Service Tag: 73ZF4M2
try a new one -
sorry I'm late in replying, in advance thank you very much for your interest in helping me, at this time I just tried the file from you sir, the laptop turns on for a few seconds then turns off, the file doesn't match, thank you
and sorry if my english is bad because i use google translateComment
sorry i'm late in replying, in advance thank you very much for your interest in helping me, at this time i just tried the file from you sir, the laptop turns on for a few seconds then turns off, the file doesn't match, thank you
sir, thank you very much, the file from you works perfectly, I replaced the ic boss and flashed the file from you, it works perfectly, thank you very much, sirComment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by lanoveyHello there,
I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
