lease friends, fix this bios, the laptop doesn't display, I've tried to clean me region but the result is still the same, I don't know how to extract files from the official Dell website, thank you
please friend fix this bios dell m14-r4 no display psu 2ma thank you
Re: please friend fix this bios dell m14-r4 no display psu 2ma thank you
Service Tag: 73ZF4M2
try a new oneAttached Filesif you find these attachements useful please consider making a small donation to the site
sorry I'm late in replying, in advance thank you very much for your interest in helping me, at this time I just tried the file from you sir, the laptop turns on for a few seconds then turns off, the file doesn't match, thank you
and sorry if my english is bad because i use google translateComment
did you wait few minute till restart around 3 time ?sorry i'm late in replying, in advance thank you very much for your interest in helping me, at this time i just tried the file from you sir, the laptop turns on for a few seconds then turns off, the file doesn't match, thank you
sir, thank you very much, the file from you works perfectly, I replaced the ic boss and flashed the file from you, it works perfectly, thank you very much, sirComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by lanoveyHello there,
I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle... - Loading...
