Help Need Working Bios Asus X412FLC rev 2.1
  • gsmcaleb
    • May 2022
    • 10
    • Philippines
    need x412flc rev 2.1 bios bin
    heres my backup bin
  • Bonzas
    • 471
    • Indonesia
    Re: Help Need Working Bios Asus X412FLC rev 2.1
    Try
    • gsmcaleb
      • May 2022
      • 10
      • Philippines
      Originally posted by Bonzas
      Try
      thanks i wil try i post feedback
      • ngocnguyenat1
        • Sep 2023
        • 10
        • viet nam
        Try
        no power
          • 20795
          Originally posted by ngocnguyenat1
          no power
          Post your original backup,laptop serial number and a picture of any QR codes or barcode stickers on the motherboard.
          All new members should read the rules before posting.
          • ngocnguyenat1
            • Sep 2023
            • 10
            • viet nam
            Help bios asus x412flc rev 2.1
            My bios is dead Asus x412flc rev 2.1 clear me
              • 20795
              Read post #5
              • ngocnguyenat1
                • Sep 2023
                • 10
                • viet nam
                Originally posted by SMDFlea
                Read post #5
                my bios is slow x412flc rev 2.1
                  • 20795
                  Anything else you can add besides the backup ?
                  • ngocnguyenat1
                    • Sep 2023
                    • 10
                    • viet nam
                    I only have the main code asus x412flc rev 2.1. because my bios is dead
                    • fcnamcoi
                      • Jul 2016
                      • 36
                      • My Home
                      Need help Clean me bios Asus X412FLC REV 2.1
                      Original file :
                        • 20795
                        Re: Need help Clean me bios Asus X412FLC REV 2.1
                        Original file :
                        Read post #5 .
                        • Bonzas
                          • 471
                          • Indonesia
                          Tested by me, it will restart 2 times before give display
                          • psinh99
                            • Feb 2015
                            • 50
                            • viet nam
                            Hello everyone, and I hope someone can help me with this issue:
                            My ASUS laptop, model A412F with motherboard code X412FLC ver 2.1, freezes at the ASUS logo when I insert an M.2 SSD and try to power it on. However, when I remove the M.2 SSD, the laptop boots straight into the BIOS setup without freezing.
                            I have tried using several new SSDs, but the issue remains the same. The original SSD from the laptop works perfectly fine when installed in another computer.
                            Do you think the BIOS might be corrupted? I have tried using the BIOS version from line #13, but the problem still persists.
                            Can anyone help me fix the BIOS using the backup I've attached below?​
                            Asus A142F
                            Boardcode: X412FLC ver 2.1
                            S/N: KCN0CV04Z77550A
                              • 20795
                              Try this - Disable VMD in bios settings or install RST drivers during windows install https://www.asus.com/support/faq/1044458/
                              • nikosystem
                                • Feb 2015
                                • 15
                                • colombia
                                hi rebuild
                                asus x412f
                                mobo. x412flc
                                L6N0CV13157025F
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11700
                                  Originally posted by nikosystem
                                  hi rebuild
                                  asus x412f
                                  mobo. x412flc
                                  L6N0CV13157025F
                                  X412FLC
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
                                  • fauxkalel
                                    ASUS Vivobook P1504F X512FA (MB X512FF) Working BIOS with DMI/SN
                                    by fauxkalel
                                    MB X512FF rev. 2.2
                                    i have laptop which during BIOS Update from Windows Update in some way broke dump -not working sound, Intel OED code 10 ("fw did not send fw ready notification").
                                    I need clean dump with inserted SN and other DMI data from my BIOS and sticker. Not sure if Win key is in BIOS.
                                    Is there way to build BIOS from update file? I tried extract it in many ways and find paterns from original dump but i think its not so easy like some time ago.. xD
                                    SN: L1NXCV10B90903C...
                                    10-29-2024, 03:34 AM
                                  • Mani .H Soltani
                                    Hello guys/gals i really need a working BIOS for this Asus E203NA Rev3.0 laptop please help :)
                                    by Mani .H Soltani
                                    Now then SMD before we start our usual Cat & Mouse game the Board im requesting a BIOS for is different then the existing thread and the thread isnt about a no POST asus its about adding Serial number to working Asus so please for the love of GOD don't merge/delete me this time.
                                    So my problem is that it don't work nothing i tried a dump it powered on once and ... no display no POST and with OG dump its dead in the waters so can anyone please help with this file ?
                                    Laptop is a Asus Notebook L203NA/DS04
                                    With a E203NA REV3.0 MB
                                    S/N L8NOCX00240534B
                                    No Service...
                                    06-08-2024, 10:47 AM
                                  • chudofermer
                                    Asus Ally rc71l bios
                                    by chudofermer
                                    Hello!
                                    Received Asus Ally rc71l with the wrong bios.
                                    Have the original package and all serial numbers.
                                    Can anyone help me understand what is wrong?
                                    Condition:
                                    Received with an original box with all serial numbers
                                    Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                                    Got the flash dump, nothing found on DMI section
                                    No Windows key, just key ID on the box
                                    What is done:
                                    1. Flash the latest bios version with serial numbers...
                                    03-05-2025, 05:42 AM
