Help Need Working Bios Asus X412FLC rev 2.1
  • gsmcaleb
    • May 2022
    • 10
    • Philippines
    need x412flc rev 2.1 bios bin
    heres my backup bin
  • Bonzas
    • 472
    • Indonesia
    Re: Help Need Working Bios Asus X412FLC rev 2.1
    Try
    • gsmcaleb
      • May 2022
      • 10
      • Philippines
      Originally posted by Bonzas
      Try
      thanks i wil try i post feedback
      • ngocnguyenat1
        • Sep 2023
        • 10
        • viet nam
        Try
        no power
          • 21679
          Originally posted by ngocnguyenat1
          no power
          Post your original backup,laptop serial number and a picture of any QR codes or barcode stickers on the motherboard.
          All new members should read the rules before posting.
          • ngocnguyenat1
            • Sep 2023
            • 10
            • viet nam
            Help bios asus x412flc rev 2.1
            My bios is dead Asus x412flc rev 2.1 clear me
              • 21679
              Read post #5
              • ngocnguyenat1
                • Sep 2023
                • 10
                • viet nam
                Originally posted by SMDFlea
                Read post #5
                my bios is slow x412flc rev 2.1
                  • 21679
                  Anything else you can add besides the backup ?
                  • ngocnguyenat1
                    • Sep 2023
                    • 10
                    • viet nam
                    I only have the main code asus x412flc rev 2.1. because my bios is dead
                    • fcnamcoi
                      • Jul 2016
                      • 36
                      • My Home
                      Need help Clean me bios Asus X412FLC REV 2.1
                      Original file :
                        • 21679
                        Re: Need help Clean me bios Asus X412FLC REV 2.1
                        Original file :
                        Read post #5 .
                        • Bonzas
                          • 472
                          • Indonesia
                          Tested by me, it will restart 2 times before give display
                          • psinh99
                            • Feb 2015
                            • 53
                            • viet nam
                            Hello everyone, and I hope someone can help me with this issue:
                            My ASUS laptop, model A412F with motherboard code X412FLC ver 2.1, freezes at the ASUS logo when I insert an M.2 SSD and try to power it on. However, when I remove the M.2 SSD, the laptop boots straight into the BIOS setup without freezing.
                            I have tried using several new SSDs, but the issue remains the same. The original SSD from the laptop works perfectly fine when installed in another computer.
                            Do you think the BIOS might be corrupted? I have tried using the BIOS version from line #13, but the problem still persists.
                            Can anyone help me fix the BIOS using the backup I've attached below?​
                            Asus A142F
                            Boardcode: X412FLC ver 2.1
                            S/N: KCN0CV04Z77550A
                              • 21679
                              Try this - Disable VMD in bios settings or install RST drivers during windows install https://www.asus.com/support/faq/1044458/
                              • nikosystem
                                • Feb 2015
                                • 15
                                • colombia
                                hi rebuild
                                asus x412f
                                mobo. x412flc
                                L6N0CV13157025F
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12269
                                  Originally posted by nikosystem
                                  hi rebuild
                                  asus x412f
                                  mobo. x412flc
                                  L6N0CV13157025F
                                  X412FLC
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
                                  • rayshine03121408
                                    I Need Working BIOS for ASUS E410MA R7.1
                                    by rayshine03121408
                                    Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
                                    Model: ASUS E410MA-TB.CL464BK
                                    SN: N8N0CX06E199324
                                    BoardModel: E410MA R7.1
                                    08-26-2025, 05:36 AM
                                  • fauxkalel
                                    ASUS Vivobook P1504F X512FA (MB X512FF) Working BIOS with DMI/SN
                                    by fauxkalel
                                    MB X512FF rev. 2.2
                                    i have laptop which during BIOS Update from Windows Update in some way broke dump -not working sound, Intel OED code 10 ("fw did not send fw ready notification").
                                    I need clean dump with inserted SN and other DMI data from my BIOS and sticker. Not sure if Win key is in BIOS.
                                    Is there way to build BIOS from update file? I tried extract it in many ways and find paterns from original dump but i think its not so easy like some time ago.. xD
                                    SN: L1NXCV10B90903C...
                                    10-29-2024, 03:34 AM
                                  • ferah831208
                                    help with bios decompose for Asus s5506ma
                                    by ferah831208
                                    I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                                    08-24-2025, 05:35 PM
