help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
  • trepachka
    • Oct 2022
    • 450
    Re: help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
    I am including BIN from both chips just in case.
    Serial# CND2203G2Y
    Thanks.
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria ๐Ÿ‡ง๐Ÿ‡ฌ
      Serial# CND2203G2Y
      Thanks.
      Program this chip only, leave the other as is. At first boot enter the bios and reset bios settings to factory default, then reset security settings, then apply, restart and you're good to go.
      Become a Badcaps supporter
      Thanks to all supporters.โ€‹
      • trepachka
        • Oct 2022
        • 450
        I will program the chip tomorrow and report back. Regards.
        • trepachka
          • Oct 2022
          • 450
          After reprogramming UK2 chip, when I press power button, I get caps lock blinking 7 times.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria ๐Ÿ‡ง๐Ÿ‡ฌ
            Most probably you didn't program the chip properly, do it again, use verification, read the chip after that and compare the content. Check the soldering of the chip and surrounding area for blown/moved components.
            • trepachka
              • Oct 2022
              • 450
              Unsoldered UK2 chip, read the data off it, then compared to the BIN you provided. No difference. Applied resoldering. Now, I am getting keyboard lights up, then caps lock and num lock both flashing 3 long and 2 short flashes.
              So, I used a different similar BIOS chip this time. I also had it reprogrammed using the BIN you provided and I am also getting caps lock and num lock both flashing 3 long and 2 short flashes. I already resoldered like 5-6 times and I am getting the same result.
              This flashing pattern indicates memory issue but I am using original memory chips and tried others I had handy. Still the same issue.
              Is it possible the BIN file is the culprit? Looking for answers.
              • TIRCEN90
                • Feb 2022
                • 23
                • Mรฉxico
                #27
                Hello, could you help me to remove the BIOS password?
                Serial: CND210375R
                Thank you, I already managed to unlock it, absolute appears inactive, could you disable it permanently?
                • Zibbo
                  • Mar 2017
                  • 203
                  • Zimbabwe
                  #28
                  Hi, requesting bios for ZBook Fury 15.6 G8 LA-K771P Rev 1.0. Laptop starts up and says "updating bios", it restarts and loops on "updating bios" over and over.
                  Serial Number: CND2252D4K
                  • retrooo
                    • Mar 2017
                    • 92
                    • mexico
                    #29
                    i need help unlocking a dump for hp zbook fury 15inch bn gpz50 la-k771p rev 1 tried hp unlocker wont work with 32mb bios and nvram method seems not be suitable for this model
                    thanks in advance
                    sn:cnd2203l49
                    • retrooo
                      • Mar 2017
                      • 92
                      • mexico
                      #30
                      update i remove the absolute and admins password,NvramActiveRegn method works with the dump from 2nd eeprom thanks !!!
                      • Dan20701
                        • Sep 2020
                        • 204
                        • United Kingdom
                        #31
                        Hello all, could someone please remove the password, I have been looking at other dumps before and after with beyond compare
                        nothing is in the same place and I am just not confident in myself just yet at giving this a go.
                        S:N : CND2402G3Q
                        Thanks.
                      • m.sabry2110
                        • Oct 2017
                        • 133
                        • egypt
                        #32
                        Try
                        • Dan20701
                          • Sep 2020
                          • 204
                          • United Kingdom
                          #33
                          Thanks a lot mate, will give these a test soon.
                          • arcomputer
                            • Jan 2019
                            • 13
                            • Pakistan
                            #34
                            hello sir we need 15.0.42.2235_COR_H_B stock file
                            • its service
                              • Feb 2021
                              • 144
                              • india
                              #35
                              Hp Zbook Fury 17.3 inc G8 With admin password can please unlock this..
                              SN# : CND3111FFD
                              PROD ID : 546D2EC#ACJ
                                • 21692
                                SN# : CND3111FFD
                                Try this https://www.badcaps.net/forum/troubl...41#post1793941
                                • its service
                                  • Feb 2021
                                  • 144
                                  • india
                                  #37
                                  Originally posted by SMDFlea
                                  not working sir i will upload main and ec dump file can u please the bios password..
                                  • its service
                                    • Feb 2021
                                    • 144
                                    • india
                                    #38
                                    SN# : CND3111FFD
                                    CAN u please unlock this bios password โ€‹
                                    • minhdigital
                                      • Nov 2022
                                      • 764
                                      • Vietnam
                                      #39
                                      SN# : CND3111FFD
                                      Send to you
                                      • its service
                                        • Feb 2021
                                        • 144
                                        • india
                                        #40
                                        Originally posted by minhdigital
                                        Send to you
                                        Password cleared but endpoint security controlled error showing
