Think pad T14 gen 3
  • renter1962
    • Jan 2025
    • 3
    Hi
    I have two lenovo's that show about the same issue. Both are T14 Gen 3 (AMD) Type 21CF. I'll create a separate reply for the 2nd laptop.
    Laptop #1:
    MTM: 21CF-CT01WW
    SN: PF4EQDYT
    PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
    Extracted BIOS: Attached
    BIOS PW: None
    Issue: Won't boot, no display, white power light turns on, fan go 100% immediately when plugged. Tried a battery drain, pinhole reset. No success.
    Huge thanks!
    Is there anything I can do on my side to fix the 2nd laptop?
    I tried to open the BIOS dump in HxD and searching for the serial but nothing was found. So I'm guessing the data in the padding regions is encrypted/encoded in a special way.
    I wasn't able to extract the binary file from the lenovo download either (iso or exe).
    Let me know if there are tools available online that would allow me to fix it without requiring your assistance.
    For older Intel based Lenovo I was able to merge my bios extract manually with HxD to the Lenovo bios from their website and it worked well (but it's also a 5 year old computer).
    • renter1962
      • Jan 2025
      • 3
      Originally posted by renter1962
      Hi
      Laptop #1:
      MTM: 21CF-CT01WW
      SN: PF4EQDYT
      BIOS PW: None
      Huge thanks!
      Ignore my previous post. I realized today that I extracted the EC and not the BIOS. BIOS is on a WSON8 and it's a quad SPI chip so I have to rethink my approach.
      • gsmdon
        • Jul 2023
        • 7
        • russia
        #43
        Hi bro! There is an at Lenovo T14 gen 3 laptop, it turns on, but there is no image
        s/n PF-40QRC2 Type 21AH-00BSUS
        I can't find the bios, and I can't create
        Please help me!
        • hoaca388
          Badcaps
          • Jan 2022
          • 12272
          #44
          Please help me!
          Read chip again ,
Name:	2025-04-01 17_55_02-(56) Con Rắn Lột Da Khó Tìm Nhất _ TGSB #1112 - YouTube.png
          • gsmdon
            • Jul 2023
            • 7
            • russia
            #45
            The BIOS is damaged, but the laptop turns on. If you install a new BIOS, the laptop will not turn on
            Apparently there's a serial number in the bios somewhere.
            Help me make a working bios out of the old and new file.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12272
              #46
              I am completely sane when I ask you to re-read the bios chip, and I also understand that the bios file is corrupted. This error is caused by the programmer. So re-read the bios chip as requested.
              • gsmdon
                • Jul 2023
                • 7
                • russia
                #47
                Sorry, there was a power surge and the laptop stopped working. It turns on, but there is no image, and there is no initialization. I counted the old bios and recorded a new one, it doesn't start at all and doesn't raise 20 volts. The old bios is flooded, it starts, but there is no image and initialization rises 20 volts. I understand that the old BIOS is damaged, but it has a section with a serial number.Without which the new bios does not work.What should I do with the new bios to make it work?
                • zubair12
                  • Dec 2022
                  • 9
                  • Dubai
                  #48
                  Think pad T14 gen 3
                  serial number PF-4FZ351
                  Type numer 21AJ-S10F00
                  Part number NM-E981
                  please resolve the issue Click image for larger version
                  every time same start like this me read
                  • ffrog
                    • Jul 2016
                    • 10
                    • russia
                    #49
                    Hello.
                    Laptop Think Pad T14 gen 3,
                    turns on, flashes three times with the on/off button.
                    NM-E441 Rev 1.0
                    SN Motherboard: PF-3X08TW
                    Type number: 21AH-007VPB
                    I've attached a bios dump, but it's soldered, so it's not necessarily native. thank you in advance.
                    • ugamazing
                      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                      by ugamazing
                      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                      08-31-2022, 07:34 AM
                    • feherhollo
                      WSON8 NEW Bios Chips READ, ERROR, ETC.
                      by feherhollo
                      I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                      I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                      For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                      11-26-2023, 09:33 AM
                    • m1ch43lzm
                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                      by m1ch43lzm
                      Hi everyone
                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                      There's also an extra OTP Secu.R...
                      09-06-2025, 05:47 PM
                    • Prott
                      [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                      by Prott
                      Hello dear badcappers!
                      The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                      Backstory:
                      After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                      If there is a way to narrow down which memory module is faulty it would make my life much...
                      06-03-2024, 12:05 PM
                    • LukeDavis
                      Is there a list of known dodgy ATI Radeon chips?
                      by LukeDavis
                      Hello again! (People are likely going to get tired of seeing posts from me lol)
                      I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                      While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                      1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                      2. ATI Mobility Radeon X1600 and the...
                      02-16-2024, 04:34 PM
