HP ProBook 440 G9 bios password
  • mshone
    • Jan 2014
    • 61
    • serbia
    #141
    Hi, I need help to unlock bios passwords on two laptops, same model. I tried with hp unlock tool “HPUnlocker.ry”, with “HPUnlocker_v1” and “RCUnlocker_v_1_0” (this is not working with files bigger then 16 mb) without success. Several times checked procedure- no mistake. Using programmer Xgecu T76 PRO. Every time password is still there.
    Model is HP Probook 440 G9
    1. s/n is 5CD2278SSX, ProdID is 6Q887ES#UUW, MoBo model is DAOX8SM8H1 REV H
    1. s/n is 5CD2278SS7, ProdID is same - 6Q887ES#UUW, MoBo model is same - DAOX8SM8H1 REV H
    Or, if somebody can give me advice where to find some working tool…. Thanks in advance.
      • 22012
      Read the post above by rex98 https://www.badcaps.net/forum/troubl...24#post3672224 ,both of your bios are U72
      • mshone
        • Jan 2014
        • 61
        • serbia
        #143
        Thanks, i will try. Thanks a lot !
        • mshone
          • Jan 2014
          • 61
          • serbia
          #144
          It is working !!!! Tnaks a lot. I learned a lot today.
            SMDFlea commented
            Editing a comment
            You`re welcome but you should also thank rex98
        • Udemzy
          • May 2017
          • 166
          • Guatemala
          #145
          Originally posted by rex98
          I noticed there's a lot of unlock request for this model HP ProBook 440 14 inch G9
          The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
          first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
          use BCU and put your original DMI.
          frequently asked questions:
          can i use this to my HP ProBook 440 14 inch G9- yes
          This is the both BID U72 and U85 its all you need.
          This bios main is from official website then added VSSTORE and patched so its fast-boot & Clearme.
          to determine your BID use hex editor and search U72 or U85 in your main bios bin, you know the rest.
          Hello,pls how do I go about this, touch not working after flashing both.
          • rex98
            • Feb 2023
            • 1293
            • Mandaue CEBU, Philippines
            #146
            flash back your original main and ec
            • niyaziyavas
              • Aug 2015
              • 3
              • Türkiye
              #147
              Hello, there is a password in the BIOS. Can you help me?
              SN: 5CD312QCRS
              PROID: 6J3K6EC#ABF
              HP PROBOOK 440 G9
              • osman68i
                • May 2015
                • 354
                • The Netherlands
                #148
                SN: 5CD312QCRS
                PROID: 6J3K6EC#ABF
                HP PROBOOK 440 G9
                your bios is u72
                Rex98 has shared clean bios
                https://www.badcaps.net/filedata/fetch?id=3672225
                • niyaziyavas
                  • Aug 2015
                  • 3
                  • Türkiye
                  #149
                  Thanks rex98, the bios you gave worked.
