Gateway GWTC116-2BL BIOS Password
  • Lucidic
    • Oct 2021
    • 9
    I am trying to get my data off this laptop and seem to have added a BIOS password so cant even boot anything I did try to use AMITSEDecrypt but I have no idea what I am looking at. can anyone help remove or if I can just find it to type in?
    the make;model is: Gateway GWTC116-2BL
    Best Regards
    Last edited by SMDFlea; 05-11-2023, 02:42 PM. Reason: Added missing model number "GWTC116-2BL" to thread title !!!
  • hardware1
    • Sep 2021
    • 2930
    • N/A
    Re: Gateway GWTC116-2BL BIOS Password
    Best Regards
    Here's your Unlocked BIOS, try it.
    all donations are welcome,
    • Lucidic
      • Oct 2021
      • 9
      it doesnt react to the power button, im not sure if that was me or the image so I will be flashing the original to confirm and update here tomorrow thank you very much for your speed and hard work
      • Capstar6
        • Aug 2023
        • US
        I am having this exact issue. How do I accomplish flashing the unlocked bios without getting past the system password?
        • megodevice
          • May 2015
          • 5
          • Kyrgyzstan
          Hello. I have the same problem.
          I tried different BIOSes, in particular from an IRBIS laptop with the same board, but it did not give any results.
          I studied the dump and realized that boot guard was active in it. Profile 2. I stitched together dumps from mine and your unlocked one.
          I tried to take only the BIOS region from the unlocked BIOS, or the whole of yours and TXE, SMIP from mine.
          In both cases, the laptop starts and works normally, the BIOS is unlocked. I also tried it with a dump from IRBIS.
          But...
          The sound, touch screen, and accelerometer do not work with the IRBIS BIOS.
          The touch screen and accelerometer are not detected in Device Manager.
          With yours everything is better, the accelerometer is visible in the device manager, but the driver does not work (code 10).
          The touch screen is detected and works, but the touches are inverse, up and down in reverse. Perhaps this is related to the accelenometer.
          The sound does not work in both cases, even though the drivers are installed normally. Neither headphones nor speakers work. The indicator jumps.
          My board model: Y116G rev X5.1
          I used FIT to build bios.
          I looked into the differences between a locked and unlocked bios.
          There are several differences in them, but I could not logically understand what exactly.
          I don't understand how you do this) but it works.
          I am attaching my BIOS, perhaps they have different versions from the ones I tried and this is causing problems with the devices.
          Please unlock)
          p.s. I tried using pure TXE and native SMIP, but it won't start. Only works with old TXE
          • volinakis
            • Jan 2021
            • 2728
            • N/A
            try
            • megodevice
              • May 2015
              • 5
              • Kyrgyzstan
              Originally posted by volinakis
              try
              It works! all! thank you legend!
              • GatewayUnlock
                • Jul 2024
                • 3
                • UNITED STATES OF AMERICA
                How do I do this? I have the flash drive already ready already. I get to the press <Esc> or <Del> but and then it says "Entering Setup..." but nothing ever happens.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11728
                  You need a programmer.
Name:	2024-07-08 17_21_43-Bộ Mô Đun Lập Trình BIOS USB CH341A 24 25 Series EEPROM + Kẹp SOIC8 SOP8 EEPROM .png
                  https://www.youtube.com/results?search_query=ch341a
                  • GatewayUnlock
                    • Jul 2024
                    • 3
                    Thank you
                    • Jse Enrique
                      • Feb 2021
                      • 38
                      • cuba
                      thanks bros
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • traxformania
                        TONGFANG "GM7TG7P" Bios Password Problem?
                        by traxformania
                        I tried :
                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                        11-15-2023, 07:32 AM
                      • tlindi
                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                        by tlindi
                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                        Ack
                        Ack
                        01-30-2025, 04:26 AM
                      • Nopslide
                        by Nopslide
                        04-01-2024, 04:27 PM
                      • BlackVisor
                        How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                        by BlackVisor
                        RedmiBook Pro 1542022 6800H
                        SKU: TM2113-39463
                        Model Number: RMA2204-AB
                        CMIIT ID: 2022AP1835
                        SN: 39463/22WD01355
                        BIOS version: RMARB5B0P1010 20230628
                        1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                        2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                        3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                        01-14-2024, 06:35 AM
