asus P552L bios clean
  • cellphoneyeta
    ShortedboardGSM
    • Oct 2015
    • 49
    • philippines
    good day.. please can someone clean my bios back up
    MOBO: P552LA_LJ MAIN BOARD REV.2.0
    SN: F6NXWU00902623F
    Thanks in advance
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: asus P552L bios clean
    SN: F6NXWU00902623F
    Thanks in advance
    You mean to clean the dust, right?
    Become a Badcaps supporter
    Thanks to all supporters.​
    • cellphoneyeta
      ShortedboardGSM
      • Oct 2015
      • 49
      • philippines
      yeah...
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        yeah...
        Really? Well, I'm glad I guessed what you mean correctly. You will have to wait a little more than usual for a result in this case I'm afraid, let's see if I have guessed right again.
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
