Generic CopyDMI Scripts
    Originally posted by SMDFlea View Post
    A script to disable ram in the bios. An alternative to the SPD ram removal tool,which is reported to have viruses.
    This works ok for DDR4,works ok for some lenovo models,it could work with others,don`t know.It does exactly the same edits as
    SPD removal tool.Tested on 12 different bios.
    Edit: By default SPD removal tool pre-selects all of the SPD RAM sections for patching.This MPS script also patches all sections. If you
    want to remove sections seperately use a hex editor.
    1. Install Tiny Hexer,you`ll find a link to it in post 1 .
    2. Make a new folder on your C: drive called "DISABLE RAM" without the quotes ""
    3. Move or copy the bios and the "Disable RAM.mps" script to the folder
    4. Rename the bios to disableram.bin
    5. Run the script,a box should pop up saying how many replacements were made, click ok,close Tiny Hexer and save when asked.
    Give if it has worked for you
    Thank you very much.
      Generic CopyDMI Scripts to complement the Experienced Copy DMI guide:
      Copy DMI info easily with Hex editing software and Macro script
      https://www.badcaps.net/forum/showthread.php?p=1214739
      Tiny Hexer - https://www.softpedia.com/get/Others...ny-hexer.shtml
      Post your generic scripts in this thread, no bios requests or any other questions , just scripts that everyone can use for any bios with the same *DMI off-sets. Posting a thank you is ok though,if you find what everyone posts useful.
      The scripts can be named anything you want but the bios naming must be the same as they are in the guide when you make the scripts otherwise they won`t work.
      *DMI. The scripts don`t have to be just for DMI,they can be used for anything that uses the same fixed offsets.
      It also works on ASUS FX502VD.
        Originally posted by mauri1990 View Post
        Thank you, worked perfectly on Lenovo V330 15ikb
        Can you share de .bin? Thanks
          You should patch your own bios, that way you will keep the serial number etc. If you don`t have a backup or want help with your own bios post your request in this thread -> https://www.badcaps.net/forum/troubl...ios-v330-15ikb
            How do I flash this newly created file after running the script ?.
              SMDFlea commented
              Editing a comment
              With an SPI programmer. Make a backup of your original bios first.
