Generic CopyDMI Scripts
  • shamzeli
    • Aug 2024
    • Turkey
    Originally posted by SMDFlea
    A script to disable ram in the bios. An alternative to the SPD ram removal tool,which is reported to have viruses.
    This works ok for DDR4,works ok for some lenovo models,it could work with others,don`t know.It does exactly the same edits as
    SPD removal tool.Tested on 12 different bios.
    Edit: By default SPD removal tool pre-selects all of the SPD RAM sections for patching.This MPS script also patches all sections. If you
    want to remove sections seperately use a hex editor.
    1. Install Tiny Hexer,you`ll find a link to it in post 1 .
    2. Make a new folder on your C: drive called "DISABLE RAM" without the quotes ""
    3. Move or copy the bios and the "Disable RAM.mps" script to the folder
    4. Rename the bios to disableram.bin
    5. Run the script,a box should pop up saying how many replacements were made, click ok,close Tiny Hexer and save when asked.
    Give if it has worked for you
    Thank you very much.
    • bushmann
      • Feb 2014
      • 147
      • Slovakia
      Generic CopyDMI Scripts to complement the Experienced Copy DMI guide:
      Copy DMI info easily with Hex editing software and Macro script
      https://www.badcaps.net/forum/showthread.php?p=1214739
      Tiny Hexer - https://www.softpedia.com/get/Others...ny-hexer.shtml
      Post your generic scripts in this thread, no bios requests or any other questions , just scripts that everyone can use for any bios with the same *DMI off-sets. Posting a thank you is ok though,if you find what everyone posts useful.
      The scripts can be named anything you want but the bios naming must be the same as they are in the guide when you make the scripts otherwise they won`t work.
      *DMI. The scripts don`t have to be just for DMI,they can be used for anything that uses the same fixed offsets.
      It also works on ASUS FX502VD.​
      • Micki90
        • Nov 2016
        • Argentina
        Originally posted by mauri1990
        Thank you, worked perfectly on Lenovo V330 15ikb
        Can you share de .bin? Thanks
          • 20518
          You should patch your own bios, that way you will keep the serial number etc. If you don`t have a backup or want help with your own bios post your request in this thread -> https://www.badcaps.net/forum/troubl...ios-v330-15ikb
          • Satyam Ganju
            • May 2025
            • India
            How do I flash this newly created file after running the script ?.
              SMDFlea commented
              Editing a comment
              With an SPI programmer. Make a backup of your original bios first.
          • Morthyr
            • Jul 2014
            • Poland
            #26
            Works with ASUS X515JA MB: X415JA R2.2
            • AlbertoZ
              • Mar 2024
              • 5
              • Italia
              #27
              Works with Asus 9461NGW P1510JCA and Acer Extensa 15 N19C1. I resumed both.
              Thanks​
                by SMDFlea
                Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                02-28-2023, 02:14 PM
              • Caimano
                Need to copy DMI info for HP ProBook 650 G2 Bios
                by Caimano
                UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
                Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
                01-03-2024, 05:19 AM
                HP Clean VSS2 dumps,fix Endpoint Security error
                by SMDFlea
                Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                the infamous **"Endpoint Security" error message.
                Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                The offsets and file sizes are part of the naming convention i`ve used for the extracted
                files.
                hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                filling everything after...
                08-08-2024, 03:14 PM
              • m0seba
                how to block copy from network access
                by m0seba
                hi
                there is a small company have 4 computers and server with windows server 2016
                all computers are entered into the server by local users, and there is shared folders on server with limited access to every computer
                my question is there any method to disable copping form all shared folders on this server, but jest disable copy form server not paste on it.
                my client want his team copy from their computers and paste on any shared folders on server, on the other way can not copy anything from shared folders to their computer.
                or any way to disable copy on windows...
                03-16-2021, 03:35 PM
              • BleedCap
                OLD Socket 478 custom bracket + NEW generic cooler
                by BleedCap
                I already posted this on vogons.
                Its a 3d printed custom bracket for socket 478.
                I used this AM4 bracket as a base design.
                Its to be use with cheap generic clip based cpu cooler.
                Reason for doing this is:
                - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                - New generic cooler is cheaper and can use bigger fan (less noise)
                I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                The processor that I was using is P4 2.4Ghz prescott....
                11-05-2023, 08:09 PM
