yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
  • couillu76
    • Jan 2022
    • 39
    before you start the procedure read the bios eeprom and save it you might need it at the end
    1do not power on your svod yet
    2plug you ribbon 30x0.5 to the left of the keyboard connector
    3test pin with testeur if it beep go to next stage
    4 open svod software select 1.8v
    5 now plug your svod
    6 select nuvoton
    7 plug charger on the board/laptop
    8 press read id
    9 select 256k
    10 read nuvoton
    11 save reading, now unplug the svod
    12 open HxD software and open your 256k file the one you just saved
    13look for offset line 36000
    14 select the all block for my case from 36010 to 36CE0 and delete it, this can change depend of the password, but the password area always start at 36000 for this EC
    15 now go back to the svod sotware and open the file you have modified, replug select 1.8v 256k size and flash it it will give you an error at the end of the flash, because the file is smaller than 256k, ignore it
    16 unplug the svod remove the keybord adapter/extender the laptop will not start if its stillconnected to the svod see picture and restart the laptop /motherboard, the laptop will restart once and the second time it will show a little dot on top left corner of the screen , wait few seconds and voilas the laptop is unlocked sometime for some reason you have to reflash the bios eeprom with the 32mb dump,not sure why
    i will join more pictures later , this method is working for l380x390 and probably for the x13 and other laptop having the same EC
    enjoy
    1
  • couillu76
    • Jan 2022
    • 39
    Re: yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with sv
    X13 GEN1 unlocked with this method i m joining the the nuvoton EC dump
    enjoy
    • kevinizm
      • Sep 2023
      • New Zealand
      has anyone attempted with x13 gen 2?
      • mily.gawel
        • Aug 2018
        • 42
        • Polska
        I do everything as in your instructions, but then I get the following message: 0177: Bad SVP data, stop POST task. And laptop turn OFF. Can you help me ?
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1358
          • France
          post your dump
          • mily.gawel
            • Aug 2018
            • 42
            • Polska
            It's my
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1358
              • France
              try
                • 22275
                It's my
                Post the laptop serial number
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1358
                  • France
                  sorry SMDFlea, I should have asked him
                  X390 Yoga Laptop (ThinkPad) - Type 20NQ
                  serial R90W2F2B in dump
                  SB20T35553W1KS99510EH /S20NQS1WC01R90W2F2B
                  • mily.gawel
                    • Aug 2018
                    • 42
                    • Polska
                    Thanks my friend, it's work perfect
                    • ssdd
                      • Jan 2024
                      • 8
                      • U.S.A
                      Tried on L15 Gen1 NPCE68xxx 256K NUVOTON and it's not working.Now L15 is not able to boot up.
                      • roli1980
                        • Nov 2020
                        • 46
                        • uk
                        hi can anyone unlock this
                        Lenovo X390
                        I5 8th Gen
                        Board Markings - F6501 1.1A / 6V - F9401 1.1A / 6V​
                        serial - R9-OY84SN
                        type number - 20NQ-S6H200
                        • peste
                          peste commented
                          Editing a comment
                          merged post..
                      • roli1980
                        • Nov 2020
                        • 46
                        • uk
                        will not detect on this model
                        X390 Yoga (Type 20NN, 20NQ) Laptop (ThinkPad) - Type 20NQ
                        • qsenc
                          • Dec 2010
                          • 45
                          Any idea how to unlock LENOVO L14 GEN 2 NUVOTON NPCE68 (read with SVDOD4)
                          SN: PF-3QQE56W
                          TYPE: 20X2-S2XW00
                            • 22275
                            SN: PF-3QQE56W
                            TYPE: 20X2-S2XW00
                            Off topic, this thread is for the X390 .Don`t hijack threads,read the rules https://www.badcaps.net/forum/troubl...before-posting
                            • qsenc
                              • Dec 2010
                              • 45
                              MY FAULT! Sorry!
                              • Barttech Computers
                                • Dec 2024
                                • 27
                                • Usa
                                Hi could someone help me with this bios, Its got a password and black screen ok via HDMI
                                Thinkpad x390 yoga
                                Serial Number is R9-0Y4DC5 Type number is 20N-S4MH00
                                THANKS GUYS
                                • Dan20701
                                  • Sep 2020
                                  • 204
                                  Hello all, I have look in to my file around the 36010 to 36CE0 mark nothing rings a bell to me.
                                  an someone check my reading and remove the password please.
                                  This was a slow reading seems to take longer than mec and ite chips I do wonder if the reading is ok.
                                  ​​​​​​​X390 Yoga (Type 20NN, 20NQ)
                                  SN, R9-0YT7E3, 20NQ-S0W600
                                  Motherboard, LBB-1 MB 18729-1
                                  ​Thanks.
                                    • 22275
                                    ​Thanks.
                                    It`s corrupted and not read properly. Compare your file and one of the others in the thread and you`ll see.
                                    • Dan20701
                                      • Sep 2020
                                      • 204
                                      Sorry about that, After a bit of messing around I got this model to read at 3.3v and all seems to be ok.
                                      Could you remove the password please, I did look at the 36010 to 36CE0 it starts off ok but at the 36CE0
                                      it was all 00 00 00 anyway so was not sure of myself., Thanks mate.
