lenovo nm-c861 disable ram in bios
  • arif3203
    • Feb 2021
    • 55
    • Banyumas
    please help me disable ram onboard lenovo nm-c861 ,use ram onboard micron (D9WWP)
  • Recycler
    • Feb 2012
    • 16
    Re: lenovo nm-c861 disable ram in bios
    Sorry for bumping someone else's thread, but I've just stumbled on the same issue with this board.
    System is ideapad 3 14-are05, board NM-C861.
    I'm looking for a way to disable onboard memory, either by hardware or BIOS.
    Schematic is not available, so it seems.
    Any help will be appreciated.
    Cheers.
    • kulokutoys
      • Jun 2010
      • 132
      • Phillippines
      try
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Cheers.
        Both schematic and BV are available. Use the search engine. Page 7 in the schematic: Board_ID [2,3,4,5], DIMM_ONLY configuration 0010 disables onboard RAM, 5 minutes job.
        Become a Badcaps supporter
        Thanks to all supporters.
        • 7Ironhide7
          • Jun 2018
          • 19
          • Ukraina
          rearranging the straps does not lead to correct operation
          • huzo
            • Sep 2014
            • 187
            • CROATIA
            Sorry guys but i don't get it... if the resistors have to be in 0010 configuration does that mean that RC44, RC41 and RC46 have to be removed, and RC38 soldered?
            • w2k6
              • Jan 2015
              • 17
              • romania
              I don't think that the configuration number has something to do with the resistors .
              Anyway , I put those resistors but it doesn't work .
              • Car edu lope
                EduTec
                • May 2024
                • 14
                • peru
                please disable integrated ram nm-c861 rev 1.0
                  • 21841
                  What is the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
                  • gkatsarel
                    • Dec 2014
                    • 20
                    • greece
                    Hello Could you please give more details. Should I move these resistors to another position on the board? If so, to which positions?
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • grimacelord
                      by grimacelord
                      Hello there.
                      History:
                      03-15-2023, 03:29 PM
                    • to5it0
                      by to5it0
                      Yesterday, 01:35 AM
                    • mkdj
                      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                      by mkdj
                      Dear all,
                      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                      Here the steps I have taken to fix the laptop:
                      - downloaded latest BIOS from Lenovo Website...
                      10-18-2025, 03:43 AM
