Dell Latitude 5521 - broadmoor 15 TGL-H BIOS file
  • dadayal82
    • Oct 2023
    • 7
    Re: Dell Latitude 5521 - broadmoor 15 TGL-H BIOS file
    Originally posted by dadayal82
    Dell Latitude 5521 - broadmoor 15 TGL-H BIOS file is attached
    Its Admin Password locked, Please Help
    Bios Dump is Attached, Thanks in advance
    Dell Latitude 5521
    Service Tag: 4RT8JL3
    Express Service Code: 10388823591
    213254-1
    Broadmoor 15 TGL-H 12L
    Bios Dump from WINBOND
    W25Q80EW [1.8V] 8 Mbits, 1 Mbytes
    • qayyum786
      • Aug 2018
      • 1933
      • INDIA
      Dell Latitude 5521
      213254-1
      posted bios is 1MB only
      it should be 32MB
      • dadayal82
        • Oct 2023
        • 7
        it should be 32MB
        This is what i got from winbond chip on my dell motherboard using ch341a usb programmer with Neoprogrammer after reading the chip.
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          send bios chip image
          • dadayal82
            • Oct 2023
            • 7
            Attached
            • hoaca388
              Badcaps
              • Jan 2022
              • 11234
              • Viet Nam
              #26
              Attached
              You must choose chips with code for example 25Q256...
              • dadayal82
                • Oct 2023
                • 7
                Yes just found one more winbond chip on other side of motherboard. But it is really closely soldered with board and hard to read with sop8 test cable.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11234
                  • Viet Nam
                  #28
                  yes just found one more winbond chip on other side of motherboard. But it is really closely soldered with board and hard to read with sop8 test cable.
                  ccc
                  • dadayal82
                    • Oct 2023
                    • 7
                    ccc
                    Already ordered this cable, waiting for the delivery.
                    • dadayal82
                      • Oct 2023
                      • 7
                      ccc
                      Received the cable & already got the bios from the chip.
                      Please help what to do next, file was around 32mb now.
                      please patch it or teach me how to edit it to remove the password.
                      Thanks in advance to all the heroes.
                      • Markus1741
                        • Sep 2020
                        • 842
                        • N/A
                        #31
                        Hello try this file i hope it helps ....
                        I wrote a Linux shell script and use egrep to search for FCAA and FDAA in the locked file.
                        The whole thing is written into a Markdown file to compare where FCAA and FDAA appear, then use the wonderful program HxD Editor to change the values from AA to 00.
                        That should be it, I'm not a professional and I can make mistakes.
                        You can compare the result in the picture.
                        • fabjodo
                          • Dec 2023
                          Hello, I hope I am not hijacking any threads.
                          I need help unlocking the BIOS for the below laptop if anyone can kindly assist.
                          Dell Latitude 5521 i7-11850H@2.50Ghz 11th Gen Bios vs 1.23
                          Service Tag: GNXDHG3-8FC8
                          Express Service: 36275295891
                          UPDATE: BIOS dump now attached
                          • fabjodo
                            fabjodo commented
                            Editing a comment
                            Anyone able to advise please?
                          • volinakis
                            volinakis commented
                            Editing a comment
                            your bios dump is ... strange. what programmer did you use to make the dump? It should have 33.554.432 bytes and it has 22.806.412 bytes and has no volumes. and .rcv extension is for a bios recovery image, did you get it from bios update? It has no use, you have to dump the bios chipset from your motherboard.
                          • fabjodo
                            fabjodo commented
                            Editing a comment
                            thanks for your reply volinakis. Is it necessary to use a programmer to dump the Bios? Sorry for the stupid question. This laptop's USB ports are blocked. I can still log in into Windows with my fingerprint but the OS keeps hanging for some reason. I managed to connect it to another laptop on the home LAN and created that BIOS dump with some DOS command I cannot remember now. Is there any other way to generate it?
                        • volinakis
                          • Jan 2021
                          • 2642
                          • N/A
                          #33
                          still don't get it after 6 months, huh? strings you have to search for are xx00FCAA and xx00FDAA. And why write "Linux shell script and use egrep to search for FCAA and FDAA" when HxD has the function to search for hex or text? Just to show off or your capacity to think is reduced?
                            • 20339
                            He`s smarter than me,i can`t code at all.I looked at one of Markuses shell scripts and it just looks like this to me
                            • volinakis
                              volinakis commented
                              Editing a comment
                              yep, he thinks he discovered warm water and walking.
                          • volinakis
                            • Jan 2021
                            • 2642
                            • N/A
                            #35
                            @fabjodo​ - yes, you have to use a programmer, read BIOS guides from this forum.
                            https://www.badcaps.net/forum/troubl...t=phoenix+bios
                            • TomWay
                              • Jul 2023
                              • 26
                              hey
                              need help im looking bios from my dell latitude 5521
                              BROADMOOR 15 TGL-H UMA
                              203040-1
                              N4KYK$CA
                                SMDFlea commented
                                Editing a comment
                                You MUST:
                                • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                • Provide a BIOS/EC dump if possible
                                • Attach files directly to your post instead of linking to external websites
                                • Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                            • cristiannec
                              • Oct 2014
                              • 48
                              • Italia
                              #37
                              Hello, Dell Latitude 5521 bios password locked,
                              Board : 203005-1 BROADMOOR 15 TGL-H 12L , i7 + discrete video
                              Service Tag : 29M1SG3
                              Express Service code : 4934795331
                              Tried to unlock it myself without succes.
                              I've attached original bios dump.
                              Thanks for your support!!
                              • minhdigital
                                • Nov 2022
                                • 719
                                • Vietnam
                                #38
                                Send to you, try
                                • cristiannec
                                  • Oct 2014
                                  • 48
                                  • Italia
                                  #39
                                  Originally posted by minhdigital
                                  Send to you, try
                                  Hello, thanks , but it's not working.
                                  Power led blink and restarts.No image
                                  • rex98
                                    • Feb 2023
                                    • 1240
                                    • Mandaue CEBU, Philippines
                                    #40
                                    try. on first boot be patient. reset security setting to defaults.
                                      DELL Latitude 5521 Notebook 5000 Specification for Upgrade or Repair
                                      This specification for the DELL Latitude 5521 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5521 boardview and 5521 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5521...
                                      09-07-2024, 06:40 AM
                                      09-07-2024, 06:31 AM
                                      09-07-2024, 02:50 AM
