np300e5c-a05tr NEED P09RAQ.bin or P04RAQ.bin
  • mkra1
    • Feb 2023
    • turkey
    Hi , my notebook is samsung np300e5c-a05tr . Motherboard is ba92-11486b .
    My original bios is p04raq . I upraeged it to p09raq .
    Now i need p09raq.bin or p04raq.bin for me cleaning to solve 30 minutes shotdown problem after cpu uprage.
    i upraged intel celeron b820 to intel i5 3380m.
    thanks.
    • 22279
    Re: np300e5c-a05tr NEED P09RAQ.bin or P04RAQ.bin
    You can`t upgrade to an i5-3380m ,the chipset is not compatible.
    https://icecat.biz/en-my/p/samsung/n...-24392232.html
    Motherboard chipset = Intel HM70 Express
    https://www.badcaps.net/forum/showpo...41&postcount=3
    2. How to clean ME/TXE region
    Cleaning ME/TXE region is required after replacing the PCH or the SoC. Sometimes the ME region gets corrupted on its own and it also required cleaning.
    Cleaning ME/TXE region consists in replacing the existing ME/TXE region in the BIOS dump by a fresh, non-paired one, retaining the manufacturer's configuration.
    Symptoms when ME region cleaning may be required include:
    • Shutdown after 30 minutes (unrelated cause is using Core i3/i5/i7 with HM70 PCH, cleaning ME region won't help)
    • Slow POST
    • Fans spinning at full speed
    • Intel MEI not working in Device Manager
    • In case of Apple machine, macOS reboots or freezes during boot
    • No POST
    • Destroyer-Br
      [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
      by Destroyer-Br
      I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
      When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
      If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
      After flashing it, the board does not power on — no signs of life.
      I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
      11-23-2025, 02:48 PM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • loopster
      Need help cleaning ME region on Zbook 17 G1 bios dump
      by loopster
      Hello guys,
      could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
      Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
      I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
      Error 10: Failed to open with processed commands.
      Unable to open file: C:\Users\Elitebook...
      06-16-2024, 09:57 AM
    • mferna14
      ME Region Cleaning for Hp 14-dq****** DA0PABMB6E0 REV: E
      by mferna14
      Hi all, I am working on this Hp 14-dq0017ca Board # DA0PABMB6E0 REV: E (S: No: 5CD016BF8T), Can anyone do a ME Region cleaning on this original BIOS. I have uploaded the original BIOS. I would really appreciate if someone can do it ASAP. Thanks in advance...
      11-09-2022, 01:24 PM
