Bios Dump Asus FX570DD
  • j.bisous
    • Apr 2021
    • 23
    • France
    Hello can you help me: i need this bios dump.
    Model: D570D
    Board: X570DD Rev2.0
    SN: L1N0CX00T31201B
    Thank you!
    • 22286
    Re: Bios Dump Asus FX570DD
    Model: D570D
    SN: L1N0CX00T31201B
    Thank you!
    Post pictures of any other QR codes or barcodes on the motherboard
    • j.bisous
      • Apr 2021
      • 23
      • France
      This is the only information i have on the motherboard. I have barcodes on the box. Maybe it will help..
      Thank you
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        Thank you
        Nothing below this?
        all donations are welcome,
        • j.bisous
          • Apr 2021
          • 23
          • France
          Nothing below this?
          Nope it's empty.
          • j.bisous
            • Apr 2021
            • 23
            • France
            I have another QR code on the daughter board
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              Model: D570D
              SN: L1N0CX00T31201B
              Thank you!
              This is a Virgin BIOS from ASUS with your DMI and Windows Key, try it.
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
