does anyone know how to convert a clevo laptop to UMA graphics only?
  • kjchatman
    • Dec 2012
    • 195
    • united states
    i have an eluktro Pro Notebook. it is basically uses a clevo mainboard. the board is model n870hp. the dgpu has been removed and the laptop comes on but it shuts off after a couple minutes since the graphics chip isn't attached. Is there a way to modify the bios or anything so that it will work without it?
  • kjchatman
    • Dec 2012
    • 195
    • united states
    Re: does anyone know how to convert a clevo laptop to UMA graphics only?
    i tried a few embedded controller files and that seems like the answer. does anyone know how to edit my ec.bin so that the machine doesn't shutdown? i can't reattach the gpu because the pads are messed up on the board but i'd still like to use the machine for non-gaming applications. it8587e is the programmable KBC
    • wacd
      • Jun 2014
      • 37
      Have you been able to find any solution to this problem?
      • wacd
        • Jun 2014
        • 37
        Or , here is the bios file you need to disable the DGPU and solve the shutdown issue.
          • 20367
          Originally posted by wacd
          Looks like i have found a solution. PM Me your original bios i'll edit it for you. @kjchatman
          All bios requests should be done here on the forum,in public.
          All EC and bios requests should be posted in the "BIOS Requests ONLY!" section
          • wacd
            • Jun 2014
            • 37
            Apologies, i shared the bios file public. Other Related posts can be deleted.
            • dellxps15
              • Feb 2014
              • 1585
              • italy
              some clevo, expecially the performance ones dont have populated coil resistor mosfet to make them uma.
              i daily use a clevo p870km with 9700k and 3080 and it cant be made uma.
              post maybe mainboard picture.
              • wacd
                • Jun 2014
                • 37
                I've came across the board mentioned in this thread today. FBVDDQ rail was burned up along with 4 memory chips and gpu memory controller. So i removed all of them and converted the board into an uma one. System started to exhibit shutdown issues just like any other clevo would do. I've been meaning to dig into this problem for a long time and saw that is a chance to do so. Done the editing and tested on the same model and it worked. Tested it around 52mins no shutdown, no crazy fanspin. Everything is as they should be. Models with no GFX supply rail can not be converted or takes a lot of effort to do fyi.
                • Sniffy
                  • Apr 2023
                  • 9
                  • Taipei
                  Would this method potentially be safe to work on a p75x-dmx?
                  I toasted the mxm card in mine a few years back and it's just been sitting on a shelf since then...
                  • wacd
                    • Jun 2014
                    • 37
                    If your device works and displays image without the graphics card and the only problem is crazy fan spin / shutdown. Editing the bios could solve the problem.
                    Need a little more detail about the mainboard , a photo of the board would be good.
                    • wacd
                      • Jun 2014
                      • 37
                      Here , the bios you need. If your mainboard code is P750DM of course.
                      If you're using K series Intel cpu , you need to replace it with one that has igpu, remember.
                      • wacd
                        • Jun 2014
                        • 37
                        I mean KF series.
                        • zmp3
                          • Sep 2019
                          • 14
                          • POland
                          Hi
                          I have removed the GPU from the Clevo N870 laptop and I have a problem with the fans. They turn on after a minute.
                          Please help. Attached is my bios.
                          The bios from this thread do not give an image on my laptop.
                          • wacd
                            • Jun 2014
                            • 37
                            Originally posted by zmp3
                            Hi
                            Here
                            • zmp3
                              • Sep 2019
                              • 14
                              • POland
                              Here
                              Hi
                              I programmed your bios, unfortunately, the same, the fans go to the max after a while and the laptop beeps
                              • wacd
                                • Jun 2014
                                • 37
                                This is what i did to many N850 device and it worked. Maybe you have some other problems as well?
                                • zmp3
                                  • Sep 2019
                                  • 14
                                  • POland
                                  With the dedicated graphics disabled in the system, the laptop worked fine. So I removed the coils initially, but the fans were running at max. I went ahead and desoldered the gpu bios and gpu chip.
                                  The problem is still the same fans work at maximum power after a while, and the laptop starts to beep.
                                  • wacd
                                    • Jun 2014
                                    • 37
                                    Yea like i said. I used this bios editing method showed in the previous picture on many n850's never had any problem converting uma.
                                    • wacd
                                      • Jun 2014
                                      • 37
                                      Try this one
                                      Also made a clearme. You can try that one too.
                                      • TecnicaNTT
                                        • Feb 2015
                                        • 64
                                        • Portugal
                                        Can somone please help me unlock this Clevo PC70DD2 BIOS? It is a InsydeH20 BIOS but the motherboard just burned a hole in the GPU VRAM VRM circuit and now there is a 19 Volt short spread across the GPU and VRAM side. I isoalted both circuits from the rest and now I can get the laptop to work but crazy fan spin and shutdown after some minutes.
                                        Laptop: Clevo
                                        Model: PC70DD2
                                        Serial Number: NPKC70DD2000E0017S
                                        Motherboard P/N: 6-77-PC70DD2-N02C-1D
                                        Motherboard S/N: NKPC70DD2000E00176
                                        • Prabuth
                                          Toshiba C660 la-6847p Convert graphics DIS to UMA. Please help.
                                          by Prabuth
                                          pwwaa la-6847p rev 1.0 Convert graphics DIS to UMA. Please help.
                                          ATI to Intel Graphics.
                                          Toshiba Satellite C660-1m0
                                          05-31-2025, 12:45 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                          Acer Aspire VN7-793G-73UU Notebook V Nitro Specification for Upgrade or Repair
                                          This specification for the Acer Aspire VN7-793G-73UU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VN7-793G-73UU boardview and VN7-793G-73UU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:59 AM
                                          Acer Predator G3-572-74FZ Notebook Helios 300 Specification for Upgrade or Repair
                                          This specification for the Acer Predator G3-572-74FZ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G3-572-74FZ boardview and G3-572-74FZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:54 AM
                                          Acer Predator PH317-51-787X Notebook Helios 300 Specification for Upgrade or Repair
                                          This specification for the Acer Predator PH317-51-787X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-787X boardview and PH317-51-787X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
