HP 440 G6 won't detect M2 after ME clean
  • tomodachi
    • Apr 2012
    • 608
    • Turkey
    Hi, changed shorted CPU on this one, now laptop post and boot to OS normal except 20 seconds delay.
    injected fresh ME using FIT, laptop now boots fine but doesn't recognise M2 drive. I m not really into FIT, can someone help me where am I doing wrong ?
    My backups attached
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: HP 440 G6 won't detect M2 after ME clean
    My backups attached
    Here's your Clean file, try it.
    Sure you did something wrong, will notice that from the first look to the size of the Compressed files.
    I think you got an error and ignored it, or you deleted the BIOS Region by accident.
    all donations are welcome,
    • tomodachi
      • Apr 2012
      • 608
      • Turkey
      Yeah you are right because I didn't pay attention to messages that popping up. Probably one of them caused this issue.
      Laptop now boot with M2 and all work fine. Many thanks for your effort
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        You're Welcome.
        • fac_franky
          [REQUEST] Help to remove BIOS PowerOn Password from HP Zbook Studio G3
          by fac_franky
          Hi Guys i have a HP Zbook Studio G3 with PowerOn BIOS Password and cannot remove it that have a BIOS CHIP 25q128fvsq i use a ch341a to read the chip and take a Backup of that with ch341A Programmer 1.29 (Selection_999(773).png image), read the content OK but if use the Verify button send a message that Don't Match
          With with ch341A Programmer 1.30 the same message, of mismatch in the verify (Selection_999(776).png image)
          The Full MB data are: HP ZBook Studio G3 Mobile Workstation LA-C401P APW5U Rev: 1A
          That is a normal situation or in effect...
          07-13-2020, 11:45 PM
        • r ez a
          5300 2 in 1 (18828-1) boot delay, tpm error
          by r ez a
          hello my friends
          i have a laptop here that came for this error
          "Alert! TPM device is not detected"
          and daley in boot
          i flashed bios with different files,aslo clean ME files
          but delay was still there
          is there any other reason for 15 sec delay in boot?
          than​
          02-03-2024, 08:23 AM
        • tribalcore20
          About 3vs out when injected
          by tribalcore20
          I have a autoshutdown instantly when pressing power button.
          I injected a 2.5V to the 3vs out/3vs and it is eating 2.545A and found out that audio ic and sio is heating up. I remove the audio ic and injected 2.5V to 3vs out/3vs and it is now eating .950A and sio os heating up. Is it normal that those 2 ic are heating up?
          11-08-2023, 09:26 AM
        • pabloroggeri
          Lenovo V360, no detect battery
          by pabloroggeri
          Hi friends!
          It does not charge or detect the battery. At first it didn't start, I programmed the BIOS with the file that is in this forum and it turned on but it doesn't detect a battery. I need to try another bios that is not the one that is already published in the forum, I suspect that the one I recorded is corrupt, or incompatible in some detail and that is why it does not detect the battery. I did all the measurements on the charguer integrated circuit and they are all ok. I think the problem comes from the data BUS side. It is for this reason that I need a different...
          07-28-2022, 08:18 AM
        • tikanot
          msi GP63 gtx not detect and keyboard mistake
          by tikanot
          Hello i have a msi GP63 and the gtx 1060 is not detect in the bios and not detect in windows , i have flash the vbios with programmer and same mistake, i have the ec do mistake with keyboard key not work or keyboard not work , i know i have to chance the ec but it's possible the ec do the gtx not detect in bios and in windows? i have check the voltage of the vga and it's good the die of the gpu is little hot at used
          04-21-2022, 10:01 AM
