About 3vs out when injected
  • tribalcore20
    • Jun 2020
    • 66
    • Philippines
    I have a autoshutdown instantly when pressing power button.
    I injected a 2.5V to the 3vs out/3vs and it is eating 2.545A and found out that audio ic and sio is heating up. I remove the audio ic and injected 2.5V to 3vs out/3vs and it is now eating .950A and sio os heating up. Is it normal that those 2 ic are heating up?
  • BalkanBoy
    • Feb 2017
    • 69
    • Croatia
    Re: About 3vs out when injected
    My suggestion is not to inject 3.3V even if that rail is working on that voltage because who knows what's shorted and 3.3V could end up on something that works on 1.05, 1.35 or similar. Always go with 0.8-0.9 volts 1st.
    It's not normal to draw such current both of those chips, check resistance to ground on capacitors around EC or sio how you call it.
    • tribalcore20
      • Jun 2020
      • 66
      • Philippines
      As long as you know what you are injecting it is find. So i found out that 3vs out is shorted because PCH is faulty and it is connected to 3.3v rail.
      • EasyGoing1
        The best way to drive a heating element?
        by EasyGoing1
        I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
        What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
        This is the general setup that I have now.
        This is what the...
        01-25-2023, 11:29 AM
      • Cemal Odabasioglu
        MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
        by Cemal Odabasioglu
        I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
        Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
        Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
        Observations...
        01-14-2025, 03:54 PM
      • sew333
        Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
        by sew333
        Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
        So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
        So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
        I expect that i will pay more for bills. But i wanna know this. Will using electrical...
        06-14-2024, 07:30 AM
      • Curious808
        LG LST5651SW stove: oven not heating properly
        by Curious808
        LG LST5651SW stove: The oven has a hidden bottom (bake) element that seems not to be heating up, but tests OK.
        PROBLEM DESCRIPTION: Set oven to 400. The display shows it heating up normally to about 365, and stops there. The top (broil) element is visible and heated. Can't see the bottom element, but the bottom of the oven isn't extremely hot. A wet cloth on the bottom doesn't sizzle and doesn't really heat up. The stovetop burners seem to be working fine.
        TESTING SO FAR:
        1) Removed the back panel and leads to the bottom element. Using multimeter, continuity...
        01-07-2023, 02:37 PM
      • edugimeno
        Thermozyklus ZE5 Heating Controller. Bus error
        by edugimeno
        Hi! I was given this board. Its supposed to be a heating controller. It can be programmed over othernet from a computer, and can manage different outputs via a "BUS" connector (there's suppossedly an external module where this BUS wires enter with some relay outputs that power on/off heating valves for different rooms
        The owner stated something like "I reversed the polarity and although the manual states that's its made to withstand reverse polarity, and would wanr the used onscreen, it ended up broken and would say "shortcut in output" all the time, or something...
        03-16-2024, 04:33 PM
