hi friends please help me fix bios this laptop turns on without display asus F751LH t
  • fredyjbi
    • Feb 2021
    • 144
    • malaysia
    hi friends please help me fix bios this laptop turns on without display asus F751LH thank you
  • hardware1
    • Sep 2021
    • 2939
    • N/A
    Re: hi friends please help me fix bios this laptop turns on without display asus F751
    Here's your New Bios file, try it and let me know.
    I think you wrote a wrong Model Number, your Model is (F571LH) not (F751LH).
    Serial Number: L9N0CX09B673395.
    all donations are welcome,
    • fredyjbi
      • Feb 2021
      • 144
      • malaysia
      Yes, that's right, I wrote the wrong series, sir, and I also just tried your bios, the results are still the same, sir, it lights up without a display, this laptop uses onboard ram, is it possible that the onboard ram is damaged, thank you
      • hardware1
        • Sep 2021
        • 2939
        • N/A
        Try those files one by one, if the problem still present you could have a hardware issue.
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • Newmultifail
          Asus g750jx Bios turns off after 30 minutes
          by Newmultifail
          I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
          I should mention that the bios update did not help.
          backup i sn...
          I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
          12-19-2024, 03:41 PM
