ASUS R753UX Original BIOS 206 needed
  • Sello2001
    • Dec 2022
    • 6
    • GER
    I need a original dump from an ASUS R753UX.
    Please help.
    Best regards.
  • hardware1
    • Sep 2021
    • 2930
    • N/A
    Re: ASUS R753UX Original BIOS 206 needed
    Please help.
    Best regards.
    Upload your Original Backup, write your device Serial Number and someone will try to help you.
    all donations are welcome,
    • Sello2001
      • Dec 2022
      • 6
      • GER
      SN: FCN0CX03230750E
      Model: R753UX - T4024T
      • hardware1
        • Sep 2021
        • 2930
        • N/A
        SN: FCN0CX03230750E
        Here's your New Bios, try it and give me the results.
        • Sello2001
          • Dec 2022
          • 6
          • GER
          NO success ... screen stays black ... :-(
          • Lisa Su
            Badcaps
            • Apr 2021
            • 213
            • Taiwan
            Try this
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
            • zdargh
              Asus Notebook GA401I, GA401 IV-BR9N6 bios needed
              by zdargh
              Hello! After an automatic windows update - it went through a bios update that has put my laptop into a boot loop that gets shorter and shorter until it just powers on and off. I can make it almost to the login screen and I tried to start the factory reset, but it just keeps entering the bootloop.
              It completely bricked at some point, so I pull the bios, but I couldn't get the DMI and windows key information to build a new one (I tried one of the guides and I can't find it), I ended up just flashing it with the ezupdate file from the asus website using a ch3a1a SPI programmer (also...
              07-12-2024, 07:03 PM
            • wakethesleep1111
              Bios File Needed for asus tuf15
              by wakethesleep1111
              Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
              05-27-2025, 10:56 PM
            • tlindi
              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
              by tlindi
              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
              Ack
              Ack
              01-30-2025, 04:26 AM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
