Lenovo yoga 9-14ITL5 BIOS
  • reeza_plus
    • Aug 2015
    • 58
    • canada
    Originally posted by hoaca388
    Yoga 9-14ITL5 Laptop (ideapad) - Type 82BG
    STILL NO DISPLAY
    Laptop powers up keyboard backlight lights up for 3 sec with no display
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Originally posted by reeza_plus
      STILL NO DISPLAY
      maybe you have a different issue
      • MAREBELE
        • Jan 2023
        • 41
        • Indonesia
        I've Been repairing laptop for a couple of year and this my first attempt at replacing a cpu.
        I use a lenovo yoga 9 14itl5, the cpu is tested and working before it being transferred to a different yoga 9 14itl5.
        I've clean the Me but nothing else, wondering what Bios modifications need to be made.
        Right now The board is definitely on because I got -PLTRST but it doesn't boot to bios
        Regard,
        • MAREBELE
          • Jan 2023
          • 41
          • Indonesia
          Here the bios dump
            • 21679
            Originally posted by MAREBELE
            Here the bios dump
            Your posts have been merged with the 9-14ITL5 BIOS request topic. Post the laptop serial number, as per the rules -> https://www.badcaps.net/forum/troubl...before-posting
            • agswireless
              • Jul 2022
              • 15
              can someone please remove the bios password lock
              \Yoga 9-14ITL5 Laptop (ideapad) - Type 82BG\
              Serial # PF35GBLV
              • peste
                peste commented
                Editing a comment
                post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
            • hardware1
              • Sep 2021
              • 2946
              • N/A
              #27
              Serial # PF35GBLV
              Here is your unlocked BIOS, try it.
              all donations are welcome,
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • AYsys
                Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
                by AYsys
                Hello dear forum members,
                I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
                I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
                Nothing was flashed here — the BIOS was only backed up.
                I created the backup using a CH341A Black programmer and NeoProgrammer....
                09-13-2025, 11:05 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • HotSaladMan
                Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                by HotSaladMan
                *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                Model : Lenovo ThinkBook 14S Yoga ITL
                S/N : MP28JT19
                MFG Date : 2022/02/09
                Factory ID PRC4
                MO : MPNXB26080FX
                MTM : 20WE001US
                MODULE FCC ID : PD9AX201NG
                IC : 1000M-AX201NG
                BOARD INFO
                FLV34 LA-KO51P
                REV : 1B 2020-08-24
                Bit of Info
                Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                chip id, so i would always uncheck the id check, so it would bypass the error
                i did in fact make...
                11-07-2024, 07:46 AM
              • beogeek
                Lenovo Yoga Slim 7 14APU8 Bios Request
                by beogeek
                I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                Attached is the bios dump in the state I received it...
                10-24-2024, 12:54 PM
