Extract Bios from Dell AFUDELL update executable
+ More Options
Posts
    • 21552
    Dell update exe used for this guide: https://www.badcaps.net/forum/showthread.php?t=115816
    Some of the newer dell updates can`t be extracted using PFS extract, or using the command line with the switches ( /writeromfile etc) .These types of updates are an AFUDELL application
    EDIT: You can also use AMI UCP extract by platomav -> https://github.com/platomav/BIOSUtilities .The last compiled windows version is attached to this post. One of the requirements
    for AMI UCP Extract to work is TianoCompress.exe ,this is avalable on Github ->
    https://github.com/tianocore/edk2-Ba...noCompress.exe .Download the RAW file and
    put it in the same directory as
    AMI UCP Extract
    Click image for larger version  Name:	1. AFUDELL Application.jpg Views:	1480 Size:	102.3 KB ID:	3156269
    To extract,first we need to use AMIUCP.Select the @R00 file ,select the extract button under the functions and select where to save the file.You can save it as Rom.bin or any other name .When you click on Apply it will be saved to the location you chose.
    Click image for larger version  Name:	2. AMIUCP Extract.JPG Views:	2617 Size:	106.9 KB ID:	2252552
    Close AMIUCP, open the saved file with a hex editor.At the top you can see the word AMIPFAT. (Note: Some extracted bios do not have this)
    Click image for larger version  Name:	3. HxD Hex Editor AMIPFAT.JPG Views:	2575 Size:	90.4 KB ID:	2252553
    The next step is to extract the file with AMI PFAT Extractor.
    After its extracted open the DATA_ALL file with a hex editor.The PFAT header at the top has been deleted but the end part hasn`t,so you need to find out where the end of the file is to edit to the correct size.
    The DATA_END file can be deleted,and the 0 KB file above it. Open the next file up "Rom.bin -- 1_10 -- BIOS_FV_FSPTM.bin" ,go to the end of the file,copy the last line as hex and search in DATA_ALL for the hex to find the end off-set.
    Click image for larger version  Name:	4. Search in DATA_ALL for hex.JPG Views:	2561 Size:	116.7 KB ID:	2252554
    Click image for larger version  Name:	5. HxD edit file size.JPG Views:	2558 Size:	179.6 KB ID:	2252555
    Alternatively you can join the files 1_01 to 1_10 using a batch command,file joining software or a hex editor.
    Credit to Ciber SLasH at vlab for the AMIUCP settings guide
  • lapfix
    • Mar 2020
    • 2756
    • my workshop
    Re: Extract Bios from Dell AFUDELL update executable
    Always with your simple and very instructive explanations
    Thank you man
    • hardware1
      • Sep 2021
      • 2945
      • N/A
      Another good lesson for me to learn a new method, Thank you.
      I deal with that type of files in a bit different way, perhaps it could be useful for someone else.
      When I can't extract the .exe file using PFS, I go and see if there are other formats such as (.rcv), I download it and that let me skip the steps for (AMIUCP), just work on (AMIPFAT).
      I don't know if the .rcv format is provided always or not.
      all donations are welcome,
      • qayyum786
        • Aug 2018
        • 1958
        • INDIA
        another good lesson for me to learn a new method, thank you.
        i deal with that type of files in a bit different way, perhaps it could be useful for someone else.
        When i can't extract the .exe file using pfs, i go and see if there are other formats such as (.rcv), i download it and that let me skip the steps for (amiucp), just work on (amipfat).
        i don't know if the .rcv format is provided always or not.
        not alwasy but maximum time they provoide that .crv file under exe
        i am using that too but few models crv file is not extractable
        • cherif 16
          • Aug 2021
          • 9
          • algeria
          THANKS SMDFlea
          • gobrasoft
            • Jun 2020
            • 6
            • Turkey
            Thanx a lot
            • skazide
              • Jul 2015
              • 143
              • morocco
              we need like button in this amazing forum
              • antok
                • Mar 2015
                • indonesia
                Terima kasih banyak , Thank you very much​
                • arashmoayyedizadeh
                  • Jan 2022
                  • 61
                  • Iran
                  hello dear experts
                  i have an alienware 17 R4
                  cpu has changed and it is 6th generation i7 6700hq
                  the only bios i could find is for 7th generation and the machine boots up and works but there is problems installing intel graphics card
                  i want to make the bios from exe file that provided by dell and i used this amazing guide from smdflea (a real hero)
                  i extracred the .exe with amiucp but when i drag it into amipfat extractor it gives me error
                  i send my .exe and extracted file and would please somone tell me where i am doing wrong with amipfat?
                  thank you very veru much
                  la-d753p
                  servicetag: 3J47RF2
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12225
                    Originally posted by arashmoayyedizadeh
                    hello dear experts
                    la-d753p
                    servicetag: 3J47RF2
                    Alienware 15 R3/17 R4
                      • Jan 2022
                      • 61
                      • Iran
                      Thank you so much my friend
                      i really appreciate
                      would you please tell me where i am doing wrong based on .exe and extracted file from amiucp?
                      • kingthink
                        • Nov 2022
                        • 19
                        • China
                        Thank you Super Moderator for sharing selflessly!
                        • Vesko356
                          [Guide] How to extract ready for programming dump from HP update executable file
                          by Vesko356
                          Recently bios requests for varios HP machines has increased more and more and as the thread title suggest this guide will help and guide members to perform an extraction of the bios file(s) from the various update executables presented as spXXXXXX.exe downloaded from the corresponding for the HP laptop model support page.
                          Keep the thread clean, do not post bios requests please.
                          Again - no requests should be made in this thread!
                          08-04-2023, 04:25 PM
                        • m1ch43lzm
                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                          by m1ch43lzm
                          Hi everyone
                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                          There's also an extra OTP Secu.R...
                          09-06-2025, 05:47 PM
                        • wishes2022
                          help to extract this samsung NP940XGK exe file
                          by wishes2022
                          Can any one help to extract this NP940XGK file ?
                          and provide one extract tools
                          Thanks...
                          07-27-2025, 10:26 PM
                        • survivalbloke
                          Unable to extract bios file from Lenovo bios exectuable
                          by survivalbloke
                          I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                          Code:
                          "innoextract 7wcn38ww.exe"
                          it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                          The trouble I'm having is that I'm not getting the newly...
                          06-12-2024, 07:55 AM
                        • alegatorul
                          Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
                          by alegatorul
                          hi,
                          i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
                          Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
                          I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
                          11-03-2024, 02:28 AM
