Alienware X14 LA-L382p LA-L381p bios
Please anyone to repair my Bios file .
It on but not Display
But i can't found the Service Tag Number there it as pilled at the back cover
Anyone should help please
Have attached the dump fileAttached FilesComment
VVVAttached Files↵
https://www.badcaps.net/donateComment
Have try it but still not display, what I noticed on the power botton is that red led light blink twice for some minute and doing that continuously
Please still need help to get rid of this fault.Comment
Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
help me! with full power supply no picture
st : FGQV1T3Attached FilesComment
Service Tag: FGQV1T3
TryComment
My bios doesn't show the image. I need help
Service tag:CJ0SSV3Attached FilesComment
hereAttached FilesComment
ALLIENWARE 14 HDS41 LA-L382P
NO DISPLAY SERVICE TAG:8TV9CY3
TryAttached Files↵
PLS ANYONE CAN HELP
NB: ATTACHED BIOS ON POST #35Comment
tryAttached FilesComment
Hi team,
Could you help me witth this BIOS?
Service TAG: 4FWYPV3
Thank you in advanceAttached FilesComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by kamkam336Hello,
I got a new mobo from Aliexpress for my Aurora r9 and everything was working fine until i did a bios update. It did not work and now i get 3x, 7x, 3x, 6x blinking code. Dell says that is a corrupt bios. So i have the ch341 and software required, i just don't have the bios.bin file.
Since the board is from Aliexpress it doesn't have a service tag, I have a copy of the .exe bios and a copy of my corrupted bios attached. Hopefully this is enough, if anyone is able to help me and requires any more information please let me know.
Thanks ...-
08-19-2024, 06:59 PM -
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
