Alienware X14 LA-L382p LA-L381p bios
Please anyone to repair my Bios file .
It on but not Display
But i can't found the Service Tag Number there it as pilled at the back cover
Anyone should help please
Have attached the dump fileAttached Filesif you find these attachements useful please consider making a small donation to the site
VVVAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Have try it but still not display, what I noticed on the power botton is that red led light blink twice for some minute and doing that continuously
Please still need help to get rid of this fault.Comment
please bulid me sv tag
BTXG2T3Attached Filesif you find these attachements useful please consider making a small donation to the site
Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
help me! with full power supply no picture
st : FGQV1T3Attached Filesif you find these attachements useful please consider making a small donation to the site
Service Tag: FGQV1T3
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
My bios doesn't show the image. I need help
Service tag:CJ0SSV3Attached Filesif you find these attachements useful please consider making a small donation to the site
hereAttached Filesif you find these attachements useful please consider making a small donation to the site
ALLIENWARE 14 HDS41 LA-L382P
NO DISPLAY SERVICE TAG:8TV9CY3
PLS ANYONE CAN HELP
NB: ATTACHED BIOS ON POST #35Comment
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi team,
Could you help me witth this BIOS?
Service TAG: 4FWYPV3
Thank you in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by kamkam336Hello,
I got a new mobo from Aliexpress for my Aurora r9 and everything was working fine until i did a bios update. It did not work and now i get 3x, 7x, 3x, 6x blinking code. Dell says that is a corrupt bios. So i have the ch341 and software required, i just don't have the bios.bin file.
Since the board is from Aliexpress it doesn't have a service tag, I have a copy of the .exe bios and a copy of my corrupted bios attached. Hopefully this is enough, if anyone is able to help me and requires any more information please let me know.
Thanks ...-
- Loading...
