DELL inspiron 15-3515 GDM54 LA-L245P bios
  • Kuroneox
    • Feb 2017
    • 24
    • México
    #41
    Dell Inspiron 15 3515
    system disable
    0474D4FF840197F1
    SERVITAG
    4BW08K3
    • hoaca388
      Badcaps
      • Jan 2022
      • 12354
      #42
      system disable
      0474D4FF840197F1
      SERVITAG
      4BW08K3
      Inspiron 15 3515
      Service Tag: 4BW08K3​
      • Carlos Simbaña
        • Jun 2024
        • 45
        • Ecuador
        #43
        Hello, please somebody could repair my bin, all the rails are ok but it has black screen, thanks.
        ST: FBZX3W3
        EX: 33377194227
        BOARD: GDM54 LA-L245P REV 1.0 (A00)
        • Carlos Simbaña
          • Jun 2024
          • 45
          • Ecuador
          #44
          Originally posted by hoaca388
          Inspiron 15 3515
          Please help me
            • 22011
            Originally posted by Carlos Simbaña
            Please help me
            Try the bios at post 36.
            • adssi
              • Jul 2020
              • Argentina
              #46
              Hi! i have this original bios dump, and no video. I cant see the tag service because no have one attached on stick. Please help.
              Regards.
                • 22011
                Regards.
                Try the bios at post 36. Your service tag is J3CZVN3
                • xloomx
                  • Oct 2020
                  • 51
                  • Argentina
                  #48
                  Many people are having BIOS issues with Dell. I have a laptop that gives me a CMOS/Battery error. The Caps Lock key light stays on solid. 1 white light and 3 amber lights. I have RTC lines enabled, Battery OK, and a data loop in the CMOS. Its a Ryzen Machine
                  Dell Inspiron 15 3515 P112F
                  Mother: GDM54 LA-L245P REV 1.0 (A00)
                  2021-07-26
                  ST: HNZ7PS3
                  EX: 38455168323
                  IC: 25Q128JWSQ
                  AMD Ryzen 5 3450U 2.1GHz YM3450C4T4MFG
                  thanks!
                  • norobert
                    • May 2020
                    • 10
                    • argentina
                    #49
                    Hello i have an Inspiron 15 3515 with no image, I think that this bios is corrupted!
                    ST:33WHHK#
                    EX:6766309155
                    BOARD:GDM54 LA-L245P 1.0(A00)
                    here is my dump! Very thanks!!!
                    • pablo_1084
                      • Jun 2017
                      • 11
                      • guatemala
                      #50
                      CAN SOMEONE HELP ME?
                      I HAVE A DELL THAT JUST FLASHES THE SCREEN AND DOESN'T WORK.
                      SERVICE TAG 751BRM3
                        • 22011
                        ST:33WHHK#
                        EX:6766309155
                        SERVICE TAG 751BRM3
                        Try the bios at post 36 from hardware1 ,just enter the service tag at first boot https://www.badcaps.net/forum/troubl...83#post3638983
                        If you want to copy the windows key from your backup to the new bios use a hex editor. Enter these start and end offsets into both C8A000 - C8A03F ,copy from the backup, paste into the new, that`s it.
                        • norobert
                          • May 2020
                          • 10
                          • argentina
                          #52
                          Hello, SMDFLEA, thank you very much for responding to my questions. I did what you mentioned: I took the newBIOS from post #36, modified the Service Tag sector, and also copied the Windows key from my oldbios.bin and pasted the newbios into the address you gave us (C8A000 - C8A03F). I want to tell you that the process didn't work for me at first because it shows that the range of the hexadecimal address array is different, and I don't know if I'm doing something wrong. I've attached an image showing the problem I think I'm having. I'd appreciate it if someone could help me create the newBIOS and explain what my mistake was.
                          ST:33WHHK
                          EX:6766309155
                          • m1ch43lzm
                            • Mar 2019
                            • 975
                            • Peru
                            #53
                            Your hex editor is tricking you by showing 15 columns instead of 16, check software settings
                            ST 33WHHK3
                            Try, BIOS from post 36, added service tag and win key
                            • norobert
                              • May 2020
                              • 10
                              • argentina
                              #54
                              ST 33WHHK3
                              Hi M1ch43lmz, I'm trying again. Can you confirm that the address range for copying and pasting the service tag into the editor is: 0x00 - 0x4B? Thank you so much!
                              • m1ch43lzm
                                • Mar 2019
                                • 975
                                • Peru
                                #55
                                I copied 000-7FF and C8A000-C8A03F from your BIOS to the working BIOS
                                • norobert
                                  • May 2020
                                  • 10
                                  • argentina
                                  #56
                                  My problem was the address. Friend, thanks for your time!
                                  • Haker418
                                    • Sep 2021
                                    • 5
                                    • ukraine
                                    #57
                                    hello friends please help. my dell vostro 3515 shows a black display. help fix the bios
                                    st:7ZLHGJ3
                                    ex:17389879023
                                    ryzen 3 my vers bios 1.28.0
                                    • LBTT1121
                                      • Nov 2024
                                      • 1077
                                      • Việt Nam
                                      #58
                                      st:7ZLHGJ3
                                      ex:17389879023
                                      try
                                      • Haker418
                                        • Sep 2021
                                        • 5
                                        • ukraine
                                        #59
                                        Originally posted by LBTT1121
                                        try
                                        Thank you very much, tell me which lines I need to copy from my bios
                                        0000- to ?
                                        • Haker418
                                          • Sep 2021
                                          • 5
                                          • ukraine
                                          #60
                                          0000- to ?
                                          thank friend its works 👍👍👍
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • sahamipoor
                                            need bios dell Inspiron 17 7000 2-in-1 p42e
                                            by sahamipoor
                                            hi...
                                            i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                                            i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                                            i updated to latest version and try other version but not working!
                                            service tag: HCQ3JW2
                                            i need your kind....
                                            10-01-2025, 11:10 AM
